Question about Amana 3.2 cu. ft. Top-Load Washer
Belt amana washer replace mod lw6501w2
Dont know how to put belt back on it was shreded when came off
  • joefixitwhen Mar 15, 2009
    new belt agitates fine when rinse cycle starts kicks motor breaker why
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Posted on Feb 28, 2009
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
Aug 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Kenmore 80 series washer
If the motor is starting? it will be just a belt replacement belts range 15-40ish
Jan 03, 2008 | Kenmore 24032\24036 Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
845 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
