Question about Sharp R-1480 Microwave Oven
Plugged in but no power, no display - Sharp R-1480 Microwave Oven
Have you tried to unplug and replug the unit/// try diff outlet
Posted on Feb 23, 2009
Clock display keeps resetting to "0"
1. Defective controller or its power supply.
2. Broken display panel.
3. Oven needs to be reset (pull plug for a minute or two to reset).
God bless you
Jun 14, 2013 | Jenn-Air JMV8186AA Microwave Oven
Condor convection chef
Possible causes:
Jun 04, 2013 | Microwave Ovens
Display & lights go out after use when door is opened, can uplug unit, then plug back in and display & lights work again until next use
If it's doing that u may have a short in the cord somewhere I would try while plugged in next time u use it don't unplug it but next time it goes out move cord a little bit n see if it comes back on if so that's the problem r u getting bad connection somewhere try another outlet too
Feb 10, 2012 | Samsung SMH7185STG Stainless Steel...
Up/down control of BROAN ELITE / RMDD4804EX/ Downdraff, in a suddent is out of order, the unit keep running up and down by itseft
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset. This should help fix the problem.
Jun 15, 2011 | Microwave Ovens
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Smeg FME24X Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
My modle # mmv4205aab lost all power, no display, no nothing. thank you
Hello- Unplug, open door, and remove screw holding display panel. Be careful, some wires may need to be unplugged. 20a fuse should be visible. If this fuse is bad- replace and address any power supply issues, such as age of wiring or circuit load-(other stuff plugged in) Hope this helps-ED
Mar 01, 2010 | Maytag Microwave Ovens
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
Sharp R-1480 Microwave Oven Logo
60 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
