Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
Error message on my Hp Officejet J6480-Fax log full
I can't receive or send faxes
  • Anonymous Mar 09, 2009
    fax log full
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Press the Setup button (Error message on my Hp Officejet J6480-Fax log ful - c01361401.gif ).
  1. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  2. ) until Fax Log displays on the contError message on my Hp Officejet J6480-Fax log ful - c01185072.jpgd then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and thError message on my Hp Officejet J6480-Fax log ful - c01235250.gifn>OK . A message that says the fax memory is clear displays on the control panel.
  4. Press the Cancel button (c01235250.gif ) to exit.
Hope this helps
Posted on Mar 11, 2009
  • Bill Davidson Oct 14, 2011
    Problem. Boom. Fixed. Thanks so much for this site.
2 Suggested Answers
  • 199 Answers
SOURCE: hp officejet j6480 all in one printer
Clear the internal memory by clearing the fax log and memory
Posted on Oct 20, 2009
Testimonial: "Thank you, problem solved"
Trying to fax and getting mesage "fax log full"
your fax RX memory is full and needs to be cleared however this should not stop you from sending transmission TX immediately however if you are going to send a memory fax you will have to clear the memory for machine to be able to store the TX you are trying to send
Oct 13, 2010 | Digital Products Hewlett Packard OfficeJet...
I can send a fax but can't receive a fax.
Hey. Try to plug only your line in the fax machine. Test if you can received. There may be a conflict between these machine.
Jan 30, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP J6480 fax memory full
A reader posted the way for me to do it. I needed to go into the menu and click on the tools bar. Then I right arrow tabbed to get to the fax section. Then right arrow tabbed to get to the memory section. Then right arrowed to get to the clear memory location. Then pressed okay
Mar 25, 2009 | Digital Products Hewlett Packard OfficeJet...
Can't receive or send faxes
In case you haven't solved this yet:
  1. Press the Setup button (c01361401.gif ).
  2. Press the Right arrow button ( > ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button ( > ) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button ( > ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button ( X ) to exit.
You can go to this web page also:
Fax Log Full Message
Thanks for using Fixya.
Feb 23, 2009 | Digital Products Hewlett Packard OfficeJet...
Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Feb 18, 2009 | Digital Products Hewlett Packard OfficeJet...
HP J6480 Fax Problems both Sending and Receiving...
Comcast is lying to you. Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Feb 04, 2009 | Digital Products Hewlett Packard OfficeJet...
Recently purchased a J6480 All in one. The fax function stopped working and the message was "Fax Log Full" cannot send or receive. How do I fix it? K. Kirschner ksk62@comcast.net
recently purchased a J6480 All in one. The fax function stopped working and the message was "Fax Log Full" cannot send or receive. How do I fix it?
K. Kirschner ksk62@comcast.net`1q```````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````
Jul 26, 2008 | Computers & Internet
Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
1,962 people viewed this question
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
