Question about Belkin Computers & Internet
I have problems with connecting to the internet when ever i want to. Comcast said it was not a problem on their end. I have both a router and modem from your company. What gives? Susan Tickel 713-885-8465.
  • Susan Tickel Feb 24, 2009
    I did move my computer closer to the router and modem, and will directly connect my router to the computer, and go from there.
    Thanks,
    Susan
    My modem and router i bought from Belkin, and it's only two months old, how do i get a refund with out the box? I spent $200.00 dollars on equipment from Belkin and it's faulty. That a lot of money to throw in the trash!!
    Susan
Hello, First I will suggest to try working directly from the modem without a router, this way you can eliminate the router as the source of the problem. Once you re-connect the PC with just the Modem, perform a power cycle on the modem to refresh the IP.
If this still does not work, try updating the drivers for your network adapter, which you will find at the respective manufactures website.
Posted on Feb 24, 2009
  • digit x Feb 24, 2009
    Hi once you eliminate the router and network adapter as the source of the problem the only posible solution is to have Comcast replace your modem. Best of luck.
    Mauricio
I got a Netgear wireless router from comcast I did the instructions on the cd, after it was detecting my connection it said that I have a static ip, I talked to comcast and said that is not right that I...
1.call comcast and ask them to put your modem on bridge mode.
2. Once the modem is on bridge mo the internet light will turn OFF
3. connect your comcast modem using the Ethernet cord to the Internet port at the back of your netgear router.
4. connect another ethernet cable from port number 1 from the back of your router and the other end should be connected at the back of your computer.
5. Then go to this website for the instruction to configure your netgear router. it includes screenshots as well for better understanding.
ftp://downloads.netgear.com/files/rp614v3_setup_manual.pdf
Sep 08, 2011 | Computers & Internet
WRT54GS ROUTER don't work with new modem
I would suggest you to look into the user manual first it may solve your problem.
Click HERE
Goodluck..
Feb 15, 2008 | Linksys Wireless-G WRT54GS Router...
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Router wont work with new modem
Hello Ladoof,
We offer support for Comcast supported routers because they are widely used in the world today. If you are using one such router and it has stopped working, then you just need to call us for instant support.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
May 08, 2009 | Blitzz Technology Computers & Internet
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
49 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
