Question about Logitech Z-540 Speaker
Problem with a slight fade out/in
I bought this set few days ago and I am very sattisfied with them, but yesterday I heard that sometimes volume slightly and fast fades out and fades back in. It can be best heard when producing NOISE for testing speakers on creative software, playing(car game...), or when playing music (but very difficulty to notice). And when I tested it on noise I found out it happens only to center end front speakers, rear works normally.
SOURCE: logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Posted on Jan 18, 2007
  • 425 Answers
SOURCE: only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
Posted on Oct 16, 2007
  • 12 Answers
SOURCE: both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Posted on Dec 27, 2007
SOURCE: Speakers not working correctly
you need to activate speaker fill i the settings
Posted on Jun 19, 2008
SOURCE: Sound is Pulsating when music plays
Ahh, I have these speakers and its common when you have the volume knob turned all the way down, to fix it, turn the volume REALLY low in windows, so that way you have to turn the volume knob on the speaker control up to 50-100%. And you will have better sound..... No pulsing
Posted on Mar 25, 2009
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
Sugden a21a - intermittent loss of channel - fading in and out sometimes left, sometimes right. Always corrects temporarily when fiddle with function knob or quickly turn up volume when it bursts forth....
had exactly the same problem myself, changed the balance, and the selector until Sugden suggested the relay. this did the job, and my amp is sorted. Shouldv'e changed this in the first place. Good as new. Shaun
Mar 14, 2010 | Audio Players & Recorders
Volume goes out after slight "pop" noise
Yea you should get a sony full HD because that is the best brand
Sep 02, 2009 | Insignia NS-LCD19 19 in. LCD TV
Problem with phone volume with HTC P3452
Yes, there is a setting where you can tell the phone not to automatically adjust the volume, this is set so that if you are in a very quiet place nobody else listens to your phone conversation. Check the settings under PHONE and UN-CHECK the automatically set volume box.
Have fun
Aug 02, 2009 | HTC Touch P3452 Smartphone
Oil light intermittent, fades, sometimes steady
Check the connection where the wire plugs onto the sender unit. If it's loose, or the wire shorts out to the body, it might flicker. If this isn't the problem, unscrew the sender unit and check your oil pressure using an oil pressure gauge screwed into the same hole. The pressure should be above 40 psi if my mind serves me correct. If it's too low you'll have to replace or check the oil pump. Did you replace the oil filter and oil recently? If the filter is blocked or the oil is old it might also cause the pressure to drop too low.
May 16, 2009 | 2001 Hyundai Elantra
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Sound fades out on both earphones
The chance of both speakers going bad at same time is remote. Your ipod is at fault and has something wrong with its output circuits. Check to make sure that there is no muting circuit inadvertently turned on.
Jun 13, 2017 | Sennheiser CX 500 Consumer Headphones
2001 Kia Rio Engine Cranks, Won't Fire, Reoccuring
i am having the same problem, thought it was ful pump, no go, I heard they had problms with the fuse box and wiring harness, my mechanic messed with mine a few days ago and it has not did it since, but I am looking at changing that. GL
Aug 01, 2008 | 2001 Kia Rio
Logitech Z-540 Speaker Logo
137 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
