Question about Acer Computers & Internet
Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
  • pkumar218 Feb 26, 2009
    hi,
    do i have any other compatible alternatives to 1 GB of DDR2 533 memory?
    regards,
    pkumar218
  • pkumar218 Feb 27, 2009
    1GB 2Rx16 PC2-5300S-555-12-A3 SAMSUNG (MADE IN KOREA)Would his RAM work in my ACER TRAVELMATE 4060 SERIES system? if so, what would be a fair price (india)?
    REGARDS,
    PRASANNAKUMAR
    Scholar:
  • 135 Answers
Your System memory is upgradeable:
256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
Regards,
Mike.
Posted on Feb 23, 2009
  • My reply is Feb 26, 2009
    Yes, you can upgrade to a maximum of 2 GB using two soDIMM modules, but to be honest, 1 GB of DDR2 should be plenty of memory for your system.
    Even the 1 GB option is 4 times your existing 256 and increasing ram, whilst always beneficial, no matter how much ram you install, it will NOT increase the performance of your system greatly.
    This can only be improved bu a faster CPU (processor).
    Thank you for your rating.
    Best wishes,
    Mike.
  • My reply is Feb 27, 2009
    I am not familiar with the memory module you mentioned or its compatibility.
    I suggest you visit http://www.crucial.com/ and use their online system tool to ensure you select the correct module.
    A 1GB module should cost around £11 GBP or approx $15
    Best wishes,
    Mike.
I want to upgrade my processor and memory on my acer travelmate 4000. I currently have an Intel Pentium M 1.5GHz 496RAM processor. I have 2 memory slots each containing 256MB type DDR PC2700, DDR...
I suggest adding 2X 1GB DDR PC2700 memory sticks. Crucial also recommends it, but as long as it's only 1gb thats DDR PC2700 per stick it's compatible, so you can shop around if you like and choose the cheapest.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Computers & Internet
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Hi sir, my acer travelmate 4061nwlci laptop gets off when power gets off. is this battery problem or accidentely some settings have been made?. pls help.
Have you checked your power saving settings in the control panel. In particular check that action taken when battery level reaches the set threshold percentage.
good luck and tell me how you went.
Jan 27, 2009 | Computers & Internet
MEMORY UPGRADE FROM DDR 256Mb to DDR2 1GB hangs when Log on/Booting
Its a memory problem obviously. Try dusting the memory slot and try inserting the memory into the slot a couple of times. If still not working, the memory may be incompatible(rarely, there are brands of boards that doesn't suit to certain brands of memory), or it may be damaged.
Sep 27, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Acer TravelMate 2303WLCi
Your particular model of laptop will allow up to 2GB of memory. Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.
As for the hard drive, I believe the standard 2.5" drive is compatible in any size you'd prefer.
Jul 31, 2008 | Acer TravelMate 2300 Notebook
Memory
Good place to check how much or what kind of ram you need. Let them do a scan, or put in what pc you have. It's safe to use.
http://www.crucial.com/index.aspx?gclid=cltp6tqhyjqcfrikxwodog4oja&ef_id=1705:3:s_72111363d43fe66f7bba91a76ae1a8e2_580972463:g1wgfnbklaoaaaklefqaaaai:20080718011627
Jul 17, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 230
yes they should do, the board should be backward compatable, as 2100 266mhz is hard to come by nowadays
Nov 23, 2007 | Acer TravelMate 2303LCi Notebook
Computers & Internet Logo
171 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
