Question about Microwave Ovens
High Point Microwave has no functions
High Point Microwave Model #EM925RSL-B; Microwave has 110 VAC to plug but no functions. Internal Failure or can this be fixed?
  • sboutin Mar 19, 2009
    Does anyone know who the manufacturer of High Point microwaves is?
  • pdeluca Apr 07, 2009
    need to know who makes Hi Point microwaves,and where to get warranty service.
I actually got ahold of the pretty much non-existent microwave division of the manufacturer called Pelonis USA, Ltd. Now if you google this company you will only find service and warrany for their heater division. The actual service number for the microwave division is a personal cell number. As stated by a tech this is a fuse issue so (get this) they only warranty the gears not the fuses. BUT it gets a little better. Through the coach's purchasing dealer you can get a replacement. This company will work through the dealers. Call the heater division's service number at 866-876-4332 (located in Grand Prairie, TX) and ask for Shalom in the microwave division. You will be given a personal cell phone number w/ area code starting in 415 or an office number with area code 847.
Posted on Dec 18, 2009
  • dovercliffs Nov 12, 2010
    I have tried everything on getting a hold of this company. My light in the microwave won't go out and there is no way to turn it off. I will try this number given above in the morning and see if I can get some information.
  • 52 Answers
Check all the fuses inside the oven, this means removing the outer casing, be careful as the capacitors can hold dangerous charges for long periods of time.there may be 2 or more fuses so check every one you can find. if this fixes it. well done!!!. if not come back and we will diagnose some more
Posted on Feb 23, 2009
All of a sudden our GE Spacemaker Microwave model JVM1549DNWW will not work, what could be wrong?
check power if good internal problem such as -bad mother board -diode-burnt out magnetron etc
Jul 09, 2016 | GE Microwave Ovens
Clicking noise when going
Sounds like a high voltage arcing. possible transformer or insulation failure causing an overload. Not a recommended consumer fix.
Feb 28, 2015 | Whirlpool Jet Chef 31 Litre 1000 Watt...
WHY MICROWAVE OVEN IS DEAD ,2000 MODEL bajaj
there could be many reasons for your microwave to be dead. First did you check if it has power coming to it? Is the plug out of the socket? Sometimes the power plug is behind the microwave and it is hard to see unless you slide it out and look. When you say dead, is the display light up? If so does it indicate PF (Power Failure)
Sometimes the internal fuse blows out because of a short, usually caused by the diodes being shorted or even the transformer or the magnatron tube itself. If you have any of these problems except for the fuse then I would recommend that you replace the microwave with a new one because yours probably wouldn't pay to fix.
Good luck,
Marty
Jun 04, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
We have a high pointe em925rsl in our brand new camper. The microwave keeps cutting out at the breaker. It has a 15amp on the breaker and it feels warm to the touch. Nothing else goes off when microwave...
test the following steps using the VOM and fix it. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).1bd565e9-a93b-42eb-b6be-1d95a42e71c1.gif
Jun 16, 2013 | Microwave Ovens
High Pointe Microwave Em925rsl Will Not Heat Food Products and also produces a strong electrical odor
This is a classic sign of the magnetron failing, the most expensive part in the microwave oven.
Jun 29, 2012 | Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Will not heat and plate does not rotate.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
I strongly recommend the techie because teh high voltage circuitry in there will still get you even when the unit is unplugged.
May 20, 2009 | Thermador MBBS Microwave Oven
Ihave high-pointe microwave oven serial #0604m00024 manufactured/ april2006 and listed 54nj has benlocked and idont know how to worked please hellpme
I also have a High Pointe Microwave Model EM925BSC SN 0608MO3508 manufactured in Aug 06. Tried to use it for the first time this weekend after buying a new Honda EU2000I to use it. The turntable does not turn automatically or when I try to turn it manually. Cooks OK. Nothing in the owner's manual that came with trailer (Zoom 178) mention how to fix the problem.
Anyone have a Ph# for High Pointe. Their Service center address is High Pointe, 2617 N Great Southwest Parkway, #100 , Grand Prarie, TX 75050.
Jun 26, 2008 | Microwave Ovens
Microwave Ovens Logo
3,001 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
