Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Hardware not recognized by computer
I followed all the insructions concerning the wall plug-in & the USB cord plug-in, then turned the photo frame on & the default images, etc. appeared on its screen. However, my computer is not recogniing it. When I click on My Computer on the desktop icon, there's is nothing on the screen to indicate that the device is available to download pics. from my computer.
  • Anonymous Apr 05, 2009
    toshiba photo frame wont reconize on my pc i havent got a disk can anyone help please
  • jrsherar Apr 07, 2009
    My computer will not display Pandigital photo frame on drive list.
  • 95 Answers
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Posted on Aug 12, 2009
Backup photos in photo frame internal memory.
There is usually some sort of "umbilical" cord that you connect between the Digital Frame unit and your computer. Should terminate in a usb male connector to plug into your computer for downloading and backing up images.
Jun 19, 2016 | PANDIGITAL 7" Digital Photo Frame With...
Black screen when turned on
Try recharging it, if you have a cord to plug in the wall or a usb cord to your computer, it should work as well.
I hope this helps.
Feb 22, 2014 | PANDIGITAL (DPF802) Digital Picture Frame
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
How to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
May 11, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
Dec 31, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
USB Connection
Hi Amanda and Lisa. Are you making sure the picture frame is off BEFORE you plug it in to your computers? Make sure you:
Turn it off before pluging it in, then plug in the USB cable. Now you can turn on the picture frame and you should see the frame's memory and any SD cards you have plugged into it in the removable drives section.
Let me know if that helps. If not let me know, and thanks for coming to FixYa. If you're happy with my answer then don't forget to rate it appropriately.
Rob
Dec 23, 2008 | PANDIGITAL 8.0" Digital Photo Frame...
USB cord fitting on my PC & downloading pics from my PC
look the usb port from the frame is for connecting a Stick / flash drive. not for connecting to pc.
Dec 15, 2008 | Nextar N7 - 7 Digital Photo Frame with...
Computer stopped recognizing USB cord from Zen sleek photo
The first problem is probably a software incompatibility between Creative's software and Windows Media Player version 11. The second problem is possibly a need to replace the battery. 3rd party batteries are about 20 dollars now.
May 28, 2008 | Creative Labs Zen Sleek Photo MP3 Player
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
483 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
Greg Ulan
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
