Question about LG MU-60PZ11 60 in. Plasma Television
Half scrin upper part show lines only ,lower part work good plasma 60PY2DR
2 Suggested Answers
rlamkin
  • 44 Answers
SOURCE: lg plasma screen half not showing lines
There is x driver board at the bottom of the set that needs to be replaced along with its x sustain. a realatively complex project.
Posted on Jul 03, 2008
Panasonic viera
Try replacing your video cable, if that doesn't work, try using a different input on the T.V. If that doesn't fix it, you may be out of luck with out an extended warranty.
Dec 06, 2013 | Panasonic TH-50PX75U Plasma HDTV
LG 50" plasma PDP50X4 only shows top half of screen, sound and top half of screen work fine....Help!
That's a relatively easy one - you have either upper or lower Y-Sustain buffer board gone bad.
if the last chip of the upper buffer has failed you may get what you get, even that this is a relatively rare type of failure.
The same would happen if the lower buffer is bad although this is again somewhat rare for a failure for those boards.
Either way you need a new buffer board and I'd start with the lower if I were you.
I assume nobody has messed up with the TV because another possible explanation would be the two buffer boards were disconnected from each other.
The best is they are neither too expensive nor hard to replace.
Hope this helps!
Oh, here's a link with something more about those boards although I am not sure it would apply to your particular case...use it as a good educational resource, but don;t expect to have the exact problem described there:
http://blog.coppelltvrepair.com/2010/10/vertical-or-horizontal-color-lines-in.html
For more help please use www.coppelltvrepair.com/diagnose ..
Sep 30, 2012 | LG Televison & Video
Brand new lg plasma 60" flat panel tve has horizontal lines accrss the screen only half way up from bottom. When you go close to tv, it looks like lots of of dots.
Hello Fixya customer,
Thank you for your question.
The are a couple of possibilities here including the logic board, lower "Y" board, lower "Y" buffers, and PDP panel. The "Y" is divided into into the lower and upper half of the screen. An experienced technician can quickly isolate the fault upon inspection and verify the supply voltages.
Thank you for using Fixya, and if I can be of further assistance please let me know.
May 01, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
My palsma screen half is black and the other half has the picture
From the brief description it sounds like the sub y board either the upper or lower one as failed (depending on which half is black. For a plasma this is a relatively in expensive repair from a shop probably a couple hundred dollars or little more. I am not in a position to give you part numbers right now but if you want to attempt to fix this yourself i can get the part numbers for the upper and lower sub y boards tomorrow. But working inside a tv can be dangerous and you can make things worse if you are not careful, so try this only if you feel confident working on electronic equipment.
Sep 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
55 inch hitachi plasma
Try re-seating your upper and lower buffer board connectors. These boards run the length of the set on top and bottom. Since your line is from the top going down I would check that one. The connector will be close to where the line is showing up on the screen.
Jun 18, 2009 | Hitachi 55PD8800 55 in. Plasma Television
Horizantal lines while showing the picture
In most cases on a plama TV the upper and lower buffer boards will cause diagonal lines to appear in the picture in top or bottom half or sometimes both.
Jan 12, 2009 | Sony FWD50PX2/S 50 in. Plasma Television
LG MU-60PZ11 60 in. Plasma Television Logo
35 people viewed this question
Computer Repairing
Computer Repairing
