Question about Maytag Dishwashers
I suspect that water is not coming out of the spray arms.  Dishes are not coming out clean.  In addition, soap dispenser is not getting rid of all of the soap.
  • 38 Answers
Check to make sure the water is getting hot and that the heater in the dishwasher is working. Check spray arms for clogged holes and debris.
Posted on Feb 23, 2009
The soap does not dispense entirely (the soap dispenser opens okay) The dishes have a soap film and at times food residue on them... It appears that not enough water is spraying on the dishes. Is there a...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | Kenmore 24 in. 17019 Built-in Dishwasher
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Bosch Dishwashers
Soap left in dispenser after wash cycle
Probably blocked spray arms is the cause of the unit not cleaning the dishes properly and also not removing all the detergent from the dispenser. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Also make sure you are only using about 2 teaspoons of detergent. you may just be using too much.
Jan 25, 2010 | Kenmore Dishwashers
Water jet arm does not work water goes into the dishwasher dishwasher drains but the arm does not work the dishes are not getting sprayed with hot water the dishes are not getting cleaned the soap in the...
In most units, the movement of the arm is powered by the water. If the water does not come out of the arms, check the filter for debris or the arm itself. This could also be caused by mechanical issues. You may want to inspect the arms itself for loose connections or worn out parts.
Oct 06, 2009 | Dishwashers
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Soap
1. You have poor pressure coming from the pump. fix this by removing the racks from dishwasher and removing/cleaning the intake filter to the pump. It is located on the floor of the dishwasher. Use a wet vac if you have it to clean the entire area and anything that might be stuck down in the pump. you would be suprised what you find doen there. Don't be afraid to remove a few phillips screws to remove a cover to the impeller. After this all should work better/cleaner AND soap dish will be washed out too.
2. make sure dishes are not stacked to block the soap dish from water spray arms.
3. remove spray arms and clean them out, especially the spray tips. Hard objects will stick in their spray tips.
Good Luck
Jul 29, 2009 | Maytag DWU9962 Dishwasher
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Kenmore dishwasher not cleaning
    Growand:
    There is a rubber tube which supplies water to the top spray arms. That is, If yours has top spray arms. This rubber tube has to make a connection when one slides the top rack back in. That tube will rot after a while, check it out.
    If the soap is not being used up, reduce the amount of soap you are using and run the dishwasher empty with a pie plate sitting on the bottom rack with a cup of distilled (cheap) vinegar in it. Run it hot and long, recheck and redo if neccessary.
    Jul 30, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
    Maytag jetclean eq plus dishwasher: soap problem
    This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
    Mar 11, 2008 | Dishwashers
    Dishwashers Logo
    189 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
