Question about Sony Playstation 3 (PS3) Console
Controller and consolle
Hi can sumone help me ,when i assign my controller 2 the ps3 it will stay ok 4 10 mins or so then turn its self off,then i have restart my ps3 does anyone have the same probs?
thanks karl
    President:
  • 2,653 Answers
You can try hard resetting the controller.
Flip the controller over, and press the reset button. It's to the right of the middle-top screw controller and consolle - ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
I've read that not allowing the controller to die will help prevent this, so try and keep your controller charged
If that doesn't work, another issue might be your cell phone and bluetooth headset (especially if you have the headset also connected to your PS3). Try turning off the headset, or if you use the headset on your PS3 as well as your phone, turn off your phone's bluetooth adapter. I was having this issue when I was using my Plantronics headset with my PS3 and cell phone.
Got this info from Kaivarri.
Let me know if that helps, if not let me know and I'll give you some more tips. Please don't forget to rate.
Thanks!
Posted on Feb 23, 2009
I have a big ben ps3 controller, and when i push the ps button the red lights just flashing and then turns off, it just wont connect to my ps3.. please help!
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 25, 2011 | Sony Wireless Controller for PS3
Nothing comes up on tv when i turn ps3 on and controllers wont connect i tryed the second Solution and still nothing comes up help
Try this if it will help you to connect the controller
3. Restart Console
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
2nd controller not working
Try this: Switch on controller 1 on, now hold down the PS button, now select Re-assign controllers and set this one as 1. Now turn it off.
Switch on controller 2 and do the same as above but Re-assign the controller as 2. Now power off.
They are both trying to grab the top spot at the same time.
If this doesn't work, connect that controller using the usb cable and do the same as above.
If the controller still has botth LED's lit when the usb cable is connected, then either the controller is faulty or the PS3 is at faulty and may have to but set back to factory defaults, do this first and if that doesn't sort it out then the controller is faulty.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Red light on the PS3 controller
ok this isnt really a problem, they will turn off after a min or two. just w8. not if this continues, like i said no problem. turn on your system and connect the usb cord to the controller. it should redirect the signal in the controller and well it should work good again. good luck
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 wireless controllers default assignment
If you have a BD Remote or a USB PS2 to PS3 controller converter connected to your PS3, it will automatically assign your PS3 controller to #2 to rectify this problem do the following:
  • Reassign BD Remote to #7.
  • USB PS2 to PS3 controller converter will need to be disconnected.
Mar 19, 2009 | Sony PlayStation® 3 (60 GB) Console
Hi my ps3 wont star i hold the start button it turns on for 2 seconds with the green blincking lights and switches it self off with the green light now turning yellow for 2 seconds then to red and stays...
It's likely that you are a victim of poor design. Your problem is referred to as the Yellow Light of Death or YLOD.
Check out my common PS3 problem and repair guide for tips and suggestions for more details.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 25, 2009 | Sony Playstation 3 (PS3) Console
Ps3 controller
everytime you play the Ps3 and you try to play a game it loads and you have to press the PS3 button again.
click the Thank me Button XD
I helped all i can
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
PS3 SETUP
Hi, This May help ?
You can change the controller port/number assignments. If the controller port/number is specified by the software, assign the appropriate controller port/number.*
Controller port 2-D cannot be assigned using the PS3 system.
You can check the current controller assignments by pressing the PS button on the controller.
Mike @ Compurepair.
Feb 19, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
