Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
The motor keeps turning on & off like it is overheating
The motor turns on & off as if it is overheating. Can you tell me what is causing this to happen?
  • 125 Answers
It sounds as if it is overheating. there is a sensor inside all motors that shuts the motor down if it reaches a certain temperature.
If your motor shuts down after running for a while then 15 minutes or so just comes back on then that is what is happening.
Could be the result of not enough air around the motor to keep it cool, or something inside the motor making it work harder than it should like the bearings going out.
Posted on Feb 26, 2009
My Nissan urban keeps overheating after it got overheated what could be the cause
Cooling fans not turning on, check to make sure the cooling fans are running when overheating occurs. Not enough coolant in the cooling system, check the coolant reservoir make sure the coolant is at at the maximum level when combustion engine is completely cool,if your coolant is low add coolant to the maximum level. (1)Start combustion engine, let it warm up but not over heat. Turn off combustion engine, when it cools completely the coolant reservoirs level will be lower . Add more coolant and keep repeating (1) until the coolant level stays the same after combustion engine completely cools down.Sensor that tells the cooling fans to turn on defective. Non functioning thermostat. Broken impeller inside Water Pump. Clogged radiator. Clogged water jackets in combustion engine. Broken drive belt. Radiator has something blocking the cooling fins(possibly a plastic bag that went against the cooling fins when driving)
Sep 20, 2017 | Nissan Cars & Trucks
My 97 jeep wrangler 4.0 is overheating badly,waterpump,thermostat,radiator,clutchfan have all been changed,and no mixing of water and oil what could it be? Also not air locked
do a compression test on cooling system just because no oil and water mix doesnt mean head gasket good ---keep an eye on fluid level possible can be burning the coolant also check flow new doesnt mean free from defects or improper installation [thermostat-water pump]
Jun 20, 2016 | Jeep Cars & Trucks
Electric motor keeps cutting out
There may be a thermal protector placed internally within the motor or motor-compressor to protect the motor and motor winding's components from dangerous overheating that can cause motor failure.
This overheating generally occurs when the motor is overloaded, a bearing seizes up, something locked the motor shaft from turning, or the motor simply fails to start properly. A failure to start may be caused by faulty start winding's in a motor.
The thermal protector consists of one or more heat-sensing elements integral with the motor or motor-compressor and an external control device. The thermal protection is in place to turn the motor off when excessive heat is generated within the motor circuitry and keep it from burning up the motor.
These thermal protectors are reset when the motor cools to a safe operating temperature. There is usually a visible red button located on the wiring side of the motor, opposite of the motor shaft, but not always. In some cases, these buttons are reset manually.
Mar 10, 2014 | Garden
Sony AV System - RM-ADU078 keep turning itself off.
Hi, by telling me it keeps turning off more or less at the same time its probably overheating. But make sure to check if
  • Are the + and - speaker cords short-circuited?
    Make sure that the speaker connection and wire are not damage or pinched.
  • Are you using only the specified speakers?
    Check that speaker connections and settings.
  • Is anything blocking the ventilation holes of the system?
    Ensure the system has proper ventilation to keep it from overheating.
If no changes email me at markusmaritz333@gmail.com
Please rate.
Nov 22, 2013 | Video Game Consoles & Games
HOOVER VHV781C-80 burning smell then stopped working
Bummer..possibly to small of belt, causing the motor to work harder then normal. Or motor overheated due to yucky hair, string..ect.. Wrapped around belt..causing stress on the belt, which drives and turns w motor. If you smell burning..( and this is my experience) it usually means broken fried belt..dirty or binding junk..which can fry both the belt and sometimes burn out the motor. So keep all working prts clean
Feb 02, 2013 | Dryers
The start capacitor keeps overheating. I replaced the capacitor and the new one is doing the same thing. Any solutions? Could the problem be the timer?
Suspect that the motor is not starting at all or is not coming to full speed which should release the start circuit. Try to turn the motor by hand, if quite difficult to turn, you need to find the cause. It could be the motor itself, so release it from any load and try for start. If the capacitor continues to heat, replace the motor. Hope this helps!
Jan 30, 2011 | Kenmore Washing Machines
The dryer keeps turning it's self off like it is overheating
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2010 | GE Dryers
2005 kia spectra overheating what may cause it?
Yes, turn on your A/C your fans should come on. Check your fuses, and you can stright wire the fan, take 2 wires unplug it and run your new wires from each post on the battery to the wires at the fan. That will tell you if you have a good fan motor. If you think the fan motor is ok and good you will have to check the wiring to the fan and your water temp switch.
Aug 04, 2009 | 2005 Kia Spectra
89 cutlas cierra overheated a few times. boild out
The overheating could be caused by a broken fan. The motor and the fan are two seperate pieces. When the engine heats up the fan comes on automatically. (keep your fingers out of the way) If the engine gets too hot and the fan does not come on, it could be electrical or a bad fan. If the fan makes noise but you don't see it turning, the motor could be bad or the plastic fan could be broken. Turn off and let the engine cool. See if the fan is attached to the motor. If the fan rotates freely it is probably attached to the motor. If it just wobles around, it is broken. Aftermarket fans are under $100.00. Original more like $200.00.
Jun 26, 2009 | 1989 Oldsmobile Cutlass Ciera
Overheating
Most normal causes for overheating would be:
  • clogged radiator,
  • insufficient coolant level (radiator and reservoir);
  • too soft radiator hoses;
  • defective/leaky water pump (impeller);
  • water pump belt/tensioner;
  • thermostat (mechanical);
  • thermal switch;
  • radiator fan, fan clutch;
  • fan relay;
  • fan fuse.
In some instances, the fan only works in conjunction with the A/C and/or heater and therefore would only work if either of those two are enabled.
Should your particular vehicle be using a radiator fan with clutch, that could also cause the fan blades not to spin even if the fan motor is turning.
Pls check the above mentioned components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | 1995 Kia Sephia
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
712 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
