Question about Canon iR 2016i Black and White Copier
I am Guna from malaysia, iam having problem with canon ir 2016j copier. Its always paper jam at bypass feeder. so i notice that the bypass tray guide broken.so i need to order the parts. i dont have parts manual, if u have please send to me. tq.
Guna,
I have iR2016 parts catalog, give me your email address, i can email to you.
my email: stablecopierssolutions@yahoo.com
Regards,
Stable
Posted on Jun 10, 2009
    Problem Solver:
  • 4 Answers
Salut
d'abord je tien a vous dire que je suis un technichien par vraiment bien qualifie dans le domaine
des photocopieur mais j'ai une petite experience dans ce sens ainsi je suis de l'algerie alore je pouvais me contacte sur cette adresse fahimriad@yahoo.fr
riad of algeria 0773 70 28 71
Posted on Mar 01, 2009
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
I need copy A3 with Canon iR 2016j Black and White Copier
Press aditional function, slect copy setting, then stack bypass, then select paper size A3.
Apr 04, 2013 | Canon iR 2016i Black and White Copier
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
My IR 6570 feeder only detect A4 paper and not F4/Legal paper and some times misread the paper
check the legal size on the glass and measure it with ur paper.this is common problem as these machines are designed for specific country papers and most times the legal paper of different countries differ .no solution dear .try using the bypass tray
Sep 16, 2011 | Canon IMAGERUNNER 6570 Copier
How to remove canon ir 400 paper feeder assembly
Why???? The unit comes out the right side of the copier. There are alot of screw to be removed. You can take the paper trays out and remove a paper jam and also replace the rollers. If the paper tray is not lifting? There is a lift gear that breaks and it is not easy to replace> I have over 20 years and it is not easy to do......
Jul 28, 2010 | Canon imageRUNNER 400S Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Regards DADF size setting in ir4570
Are you sure the problem is not coming from the paper tray????
Open the paper tray and look at the guides that hold the paper, if Letter paper is in tray make sure the guides are set against the paper, also look "behind" the tray for paper it could be changing the paper size.
Oct 03, 2008 | Canon imageRUNNER 4570 Copier
Canon iR 2016i Black and White Copier Logo
189 people viewed this question
old marine
old marine
