Question about Microsoft Xbox 360 Console
I cannot get my disc to eject from the xbox
When trying to reject the tray from the xbox i can hear the motor going round but the tray doesn't move.Anybody any ideas?
  • 3 Answers
Open it up one of the gears may have been broken
Posted on Feb 23, 2009
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
Nov 28, 2013 | Magnavox DV220MW9 DVD Player VCR
Tip
If your Xbox 360 Disc tray won't eject
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on Feb 02, 2010 | Video Game Consoles & Games
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Hi,the door for putting disc in wont open.every time i push the button there is noise comn from machine like its trying to open but it cant?
This happens to me every now and then.
Here is how you can get around it:
Sometimes, you cannot open the disc tray on your Xbox 360 console by pressing the eject button. Any of the following things may cause this problem:
  • There is a hardware failure that affects the console, the disk drive, or the eject button.
  • A disc is lodged in the mechanism.
  • The clear protective plastic strip that is applied to the front of the tray to protect it during shipping is preventing the disc tray from opening.
To manually eject the disc from the disc tray, follow these steps:
  1. Unplug the power cord from your Xbox console. For more information about how to disconnect the power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect your Xbox 360 power supply
  2. Position your Xbox 360 console horizontally, as you would position a VCR or a stereo component.
  3. Remove the faceplate from your Xbox console. For more information about how to remove the console faceplate, click the following article number to view the article in the Microsoft Knowledge Base: 907331 (http://support.microsoft.com/kb/907331/ ) How to attach or remove the faceplate on your Xbox 360 console
  4. Depending on the kind of disk drive that you have in your Xbox 360 console, you can use one of the following methods. Note In each case, make sure that you align the tool (a paper clip or stiff wire) to pass through another notch behind the hole on the console casing. Collapse this imageExpand this image906935.jpg
    • Method A: Insert a straightened paper clip or other small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paper clip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method B: Insert a straightened paper clip or other small, stiff wire into the second hole from the left side of the disc tray. Push the paper clip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method C: Insert a straightened paper clip or other small, stiff wire into the hole that is directly under the "X3" logo on the Xbox 360 label on the disc tray to release the disc tray. The hole is located about 1 inch from the right edge of the disc tray.
  5. After you release the disc tray, the tray pops out slightly. You can pull the tray out the rest of the way to remove the disc. Note If you use method A or Method C in step 4, you may have to firmly press the disc eject mechanism to eject the disc tray.
  6. If you determine that a hardware failure has occurred that affects your Xbox console, contact Xbox Customer Support or submit a repair request for your Xbox 360 console.
(Information taken from: http://support.microsoft.com/kb/906935)
Hope it helped.
Nov 16, 2009 | Microsoft Xbox Console
Disc tray wont open when eject button pressed on ps2
The disc tray motor needs to be replaced. You can find one on ebay. A relatively easy fix. Good luck!
Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
I have repaired my red rings the xbox is running and everything is great except for...my disc tray will not open at all. I tried going on the dashboard and opening the disc tray this way and it still will...
If you hear the motor trying to open it then slap the top
firmly as you press eject that should break it free ,
If that's the case it's just hanging up on the front flange.
You know what that means ... Take it apart again and clear
the snag . if you don't hear the motor then the
power cable to the drive got pulled lose ether way
you gotta strip it again. Thats kinda easy .
Hope that helped a little
Rob
Sep 20, 2009 | Microsoft Xbox 360 Console
Original Xbox disc tray not opening properly
I found this posted on cheapassgamer.com
Greetings, Ladies and Gentlemen.
Since I was able to solve my Xbox's tray problem completely (for now) due to this site, I felt it necessary to contribute to the forum, in order to (hopefully) help the next person with the same problem.
First, let me note that my Xbox has a Samsung drive. This method may only work if you have a Samsung or Hitachi drive, as they have the lever action emergency release.
Issue:
A) Xbox DVD tray will not eject when eject button is pressed, instead making a clunk / thump noise, as if being blocked from ejecting due to media inserted incorrectly – irregardless if media is present in the tray.
B) Tray will sometimes eject if button is pressed multiple times.
C) Tray will only eject if Xbox is thumped upon directly above the tray.
Solution:
A) First, go to http://www.xbox-mod.co.uk/index.php?...mergency-eject . Then, scrounge up a paper clip and proceed to manually eject your DVD tray.
B) Next, remove the Xbox logo front panel from the DVD tray. This is fairly easy to do, but you must be gentle, or you might break the tray or the front panel. The way to remove it is to take a pair of needle nose pliers and use them to gently pull the bottom clips away from the tray's underbelly before pushing the front panel up. You can also unclip one side, then the other if you are having difficulty.
C) Use the eject button to close the tray. Now open it again. If it still refuses to open (as did mine), use the paperclip and manually eject the tray.
D) Now, loop your finger through the open DVD laser slot in the tray, and gently pull the tray towards you – it will come out a wee bit more, and then stop. Do not force the tray to extend any farther than that.
E) WHILE THE DRIVE IS STILL OPEN, use your paperclip on the manual eject lever. It may take a moment to trigger it, as it is currently depressed, but if your Xbox and DVD Rom are like mine, it will actually draw the tray back in.
F) Poke the Eject button. It should pop open without any argument at this point. Try it a few times, just to be sure, if you'd like. Then, slide the front panel back onto the tray, and you should be good to go… until the next time the P.O.S. decides to slip a gear.
What's that? Slip a gear? Yep. As far as I can tell, that's exactly what is causing the trouble with the drives. Pushing them closed with your finger will force the motor to engage, yes? Well, eventually it seems the cheap DVD Rom's in the Xbox get fouled up, the motor kicks in a bit too late, closes the tray too far, and slips a gear. Then it will clunk / thump at you impotently until you fix it. What we have just done seems to reset the engagement point on the motor, and allows the eject button to work properly again. An easy solution to this problem is to always use the eject button to load and eject media, but you can't always ensure your guests are going to adhere to that policy (Or that the Xbox won't pull it shut too hard just to spite you, the foul tempered little…).
For Thompson and Phillips Drives, that use a gear to manually eject the tray, I would assume that pulling the tray forward, then advancing the gear manually until it refuses to do so, and then pushing the eject button might work. If anyone tries this and succeeds, reply to this message and let us know.
Thanks again for leading me to my solution (even if it may only be temporary), and I hope my suggestions have led you to yours."
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Microsoft Xbox Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
