Question about Mtd 22" Yard Machine Push Mower
Auger broke off the saft on my 21" Yard Machine snow blower
Does anyone have an idea on how to remove the augar pulley? Does it thread on the shaft clockwisw or counter clockwise? Also any thoghts on how best to hold the auger in place while removing the pulley - THANKS
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Yard Machines snow blower
The bearing can be a bugger to remove....and it sounds like the bearing may also be bad... so you will want to replace that also...
To get it off make sure that the set screw(s) are backed out with an allen wrench...the set screws will be in a small hole in the lip of the bearing....an allen wrench is a six sides wrench that comes in many sizes... the screws may also be a metric size...
then to remove the bearing you will need to use a gear puller that will grab the bearing equally with thre jaws and the use the shaft for leverage as you turn the screw to pull the bearing off of the shaft...
You will bugger up the shaft if you keep trying without the proper tools and then you will really have a mess on your hands...
heatman101
Posted on Dec 21, 2010
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
How to remove the right hand auger from a nova performance snow blower model 629104x31
remove the whole auger from machine and then remove the shear bolts. Slide the auger off shaft
Aug 25, 2014 | Garden
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
Yard Machine 5.2 HP snow blower Auger is not rotating not throughing / cutting snow.
Hi, The only thing I can think of is that your sheer pins are broken. Can you turn the auger by hand? If you can, look at the shaft that the auger is welded to, If you can look for bolts or holes on the auger center shaft, You will have to punch out anything that is left there. If that's the problem measure the diameter and length of the old bolts, or go to a shop that sells parts to get new sheer pins. You can also use ordinary bolts that will work well. Have you checked your belt to see if it is broken or has come off the pulley or if the belt tensionner is still on the belt or has come off not providing the right amount of tension so the belt does not slip in the pulleys and is able to turn the auger. Regards and good luck. I hope that is the problem and can be fixed easily and is cheap to do.
Jan 14, 2011 | Garden
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 | Garden
I need to remove my auger on my snow thrower, but I am not sure how to remove the auger bearings to allow the auger to come out.
There should be bolts to remove on each outer end of the auger shaft, and the blower shaft must be removed from the rear bearing/pulley at the rear of the blower housing. Look for bolts to release the entire blower housing from the engine/drive section. On out Sears unit, there is a nut on the end of the engine crankshaft that allows the two drive belts to be removed. If you don't have the service manual, be sure to make notes of each part as it comes off of the machine (there will be many). Check the condition of each belt and also the rear bearing that the blower shaft came out of. The gear box at the front end of the blower shaft must come apart to release the auger shaft. This is not a job for the faint of heart! Good luck!
Nov 28, 2010 | Husqvarna Garden
Screeching snow blower
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
Jan 14, 2009 | Toro Lawn Mower With Toro Power Tools
Mtd 22" Yard Machine Push Mower Logo
118 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
