Question about Behringer EUROPOWER EP1500 Car Audio Amplifier
Behringer 1500 red light. Amp powers up fan comes on then a have a channel A red light that doesn't go out. No Sound
  • djrobneal00 Feb 24, 2009
    have the amp completely unhooked and no wires attached. so most likely the channel is bad. but i still can't get sound out of cannel b either. it done this right in the middle of a show. luckely around closing time. thanks
    Problem Solver:
  • 11 Answers
RED LIGHT MEANS THERE IS EITHER WIRES TOUCHING OR A BAD GROUND. IN WORSE CASE SCENERIO THE A CHANNEL IS BLOWN
Posted on Feb 24, 2009
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
Oct 28, 2013 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer power amp epq2000 limit lights is staying on
i have the same problem... no solution found for mine...and you?
May 13, 2012 | Behringer Epq2000 Professional Power...
It hs no instument lighting,Chanell level indicators and master level indicator
is there power to it? does sound come out of it? if not it could be fried or about to fry. Behringer makes low end products, which tend to break fast. if you dont have any sound or lights chances are its unfixable
May 25, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Can't get no output sound from my Behringer PMX660M mixer. All lights are on, power on is on, line-ins work correctly; speakon cables good but sound when instrument played through mixer.
The power amps may be blown... PLEASE read my tip on Fixya about the hazard with PMP mixers if you use Speakon to 1/4 inch cables. The sleeve or barrel of the Channel A plug is the hot, not the tip. Touch it to ground and goodbye Channel A of the amp.
Do this test: Plug a set of earphones into the Main out L and R jacks and see if audio comes out there. (it will only be in one side of the headphone and not too strong... If both L and R have signal there is a problem with the power amp or its configuration. Make sure the slide switch is up in the MAIN L/R position (top position) If all that is correct, the power amps have probably blown. Repair takes a lot of work and getting parts from Behringer now is really hard. The amp module is an HCA2400 and the only source seems to be FullCompass.com...
Mar 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Is my Behringer Powered Mixer PMP2000 cooling fan suppose to run continuosly. It has a distracting hum in our small church. I don't remember it always running (fan) when we first started using it? Help :-[
Sorry, the fan is thermally controlled and USUALLY will run at low speed when unit is lightly loaded. In hot weather or driven hard it will run faster and louder.
Whatever you do, do NOT block airflow... these are a dual 400 Watt continuous amp (600 a side peak) and they need to breathe !!!
If you can duct cool air to it, that will help. You could also try sound absorbing baffles while maintaining adequate clearance for airflow.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
There is no sound being sent to the speakers and
Check if sound to headphone jack is normal. If so, try the headphones in the MAIN out 1/4 inch jacks. If there is sound (it will be a lot less as this is a line level output), then the power amps are probably popped... and maybe the main power supply. The auxilary runs all the visible stuff.
If under warranty, take it for repair. Behringer doesn't provide schematics so working on these is a problem. In the PMP5000 there is a chronic problem of insulation breakdown on the rear most amp that can wipe out the power supply as well as the switching transistors in the amplifier. (This is a class D switching/ energy recovery type amp).
Feb 21, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP1500 Car Audio Amplifier Logo
310 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
