Question about Dell Latitude D600 Notebook
THE FAN MAKE NOISE WHEN RUNNING - Dell Latitude D600 Notebook
    Problem Solver:
  • 15 Answers
Two possable fixes. One easy, the other may not.
1) Buy a can of PC Air and clean out the vent as best as possable. This may clean out and possable to make a diffrence.
2) Buy a new fan and install or pay to have installed.
Posted on Feb 23, 2009
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Refrigerator noise
cause of this problem is grated shaft bush of compressor. replace compressor
Mar 14, 2014 | Home
When running the noise sounds like the fan is not working correctly.
when microwave is running the fan sounds like it is grinding
Feb 03, 2013 | GE JVM3670 Microwave Oven
Fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
Noisy fan running constantly - fan noise caused by ice build up
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 27, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
High pitched noise
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Sep 08, 2009 | GE Refrigerators
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
Dell Latitude D600 Notebook Logo
132 people viewed this question
Alun Cox
