Question about Toshiba Satellite A105-S4004 Notebook
I had to replace my Toshiba A105 screen recently due to damage. I installed the new screen myself and it worked fine for a while, but now it has a pink vertical line about an inch thick running down the middle of my screen. Was the screen I bought faulty and what should I do to fix it?
  • 3 more comments
  • amitytv Feb 23, 2009
    Yes, I did. It was not refurbished. It was supposed to be new.
    Within seconds of first turning it on, the line appears. There are about 2 or 3 seconds where it it is not there though, at the beginning. Does that help?
  • jennibvolley Mar 30, 2009
    My problem is the same except it gradually gets worse until my entire screen is filled with lines. Sometimes I can just re-adjust my computer and they will go away, but other times I have to re-start it. Once restarted it will remain clear for a day or two until the lines start to come back...
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    to rule out faulty graphics drivers, do you get this pink line from post? (when you first turn the pc on)
  • Lee Hodgson
    Did you buy the screen brand new?
  • Toshiba Master
  • 4,806 Answers
Ok then, take it apart again and make sure all the connections are well seated, check the inverter (circuit board under the screen) the ribbon cable that goes behind the the screen and the block connector that attaches to the motherboard. If all theses connections are well seated and you still get the pink line, the screen is defective and you need to send it back.
Good luck and thanks for using Fixya!!
Posted on Feb 23, 2009
How do I myself replace speakers in my Toshiba Satellite A105, step by step,correctly ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand laptops are given with illustrations.
Aug 11, 2014 | Toshiba Satellite A105 Notebook
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
I have toshiba satellite A105-2102 laptop in working condition.As hard disk had gone faulty, i replaced and installed windows xp. working fine.I am interested to put this laptop as it was supplied when it...
You can not download the software CD but you may be able to find most of the drivers and supporting software on toshiba's website. To get the actual software CD / recovery disk, you will have to contact toshiba. They will charge you about $40 for it.
Chris
Aug 10, 2011 | Computers & Internet
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Put US-made 120 V Toshiba into 240 V electric current. It blew.
Did the smoke come from the computer or the power supply. Most of the power supply boxes for notebooks are multi voltage and can auto switch from 110 to 220. If the smoke came from the power supply box it may not have damaged the computer. If it came from the system, the power stage of the motherboard cooked and it will need replaced. If it is an older laptop it will probably not be worth fixing as it may cost more than half of the cost or a new one. I would try using a different power supply to test it and see if it comes on. If not, you may be looking at getting your data transferred to a new computer.
Best of luck
Cheers
Jan 01, 2009 | Toshiba Satellite A105 Notebook
A105-s2716
The problem with the LCD screen , if the external display is working fine. The LCD needs a replacement. The same thing happened on my Dell and we had to replace the Lcd. The same can occur because the LCD cable gets damaged when you open or close the LCD
Thanks
Proton
Aug 02, 2008 | Toshiba Satellite A105 Notebook
Power cord
If the power adapter no longer works it's time for a new one. Try brighton on ebay. They have great adapters with warrenty. I use them myself.
Jul 07, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Screen Problem
Only thing i can say is this. Try to get a new screen because from what you are describing. I believe that the monitor is damaged inside. If you got the laptop recently i will suggest that you get it returned for a different one.
Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
