Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
2003 polaris 550 trail touring,revearse not working
Snowmobile seemed to be idling high,and then noticed i had no revearse,adjusted idling to lower rpms but still no revearse although light comes on monmentarily.
  • Anonymous Mar 17, 2014
    2003 polaris snowmobile mid range speed and top speed has problems.
    Problem Solver:
  • 12 Answers
The high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
2013 polaris 500 touring snowmobile reverse problems. I believe the idle may be to high.
please add video to your complaint, also polaris shifters have been known to have issues with the linkage. so please inspect the linkage. you could lower your idle a bit but this bike always worked in the past? idle didnt adjust its self? i have always found excessive play in the linkage and i just wasnt pushing far enough back
Feb 22, 2017 | Cars & Trucks
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Can the timing be set on a 2012 polaris 550 snowmobile
no. and you should not need to. Just reassemble and it will be set.
Mar 01, 2015 | Polaris 2012 LXT 550 IQ
Looses power
You are either Losing Power (Engine) or Primary is Failing.
If you are losing it after it warms up, look at the RPM. If the Engine RPM is staying HIGH, then you have a Primary Clutch Issue.
If you are Losing RPM, then you are losing Compression. Best thing to do is look at the Compression of the Engine and if the Compression is LOWER on one Cylinder (Normally the PTO SIDE) then you are going to be doing a top end rebuild.
There is a slight 3rd scenerio (CDI is going bad).
Jan 28, 2014 | Polaris 2009 Trail Touring DLX
How can i tell if the oil pump is working// blown piston /550 polaris
Pumps are bad on 2003-2008 550 fans, they get air bubbles with consistant throttle positoins-speed. Contact Polaris they will pay for the parts, not labor.
Jan 04, 2010 | Polaris New Genuine Polaris Snowmobile...
Spark plug removal on a polaris 750 IQ touring snowmobile.
May 01, 2017 | Polaris ATV
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
803 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
