Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
Behringer inboard effects modul board
The effects module board in my PMH 1000 is busted. Where can I buy a new board. The model states DF0482
  • Behringer Master
  • 5,603 Answers
BEFORE you throw away the board, I found a similar board in a different unit that had a SIMPLE problem. Check if your board has its own built in 5 volt power rectifier and regulator. The bad one I had required ONLY changing the DC filter electrolytic cap that, for my estimation, is undersized capacity wise.
Posted on Jul 28, 2009
Are they compatible with Huawei ONT HG8546M C+ modules?
Yes, it can be compatible, if Huawei GPFD board with B+ SFP modules, it doesn't effect if the ONT (Huawei HG8546M) with B+ or C+ modules.
Jan 04, 2018 | Huawei Computers & Internet
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try:
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
I replaced the transformer and fuse which is in a sealed compartment above the power supply connection in djx 700 (behringer) and still have humming in the new transformer
Transformers rarely fail... you wasted money on that... Likely one of the rectifier diodes/module or filter caps has shorted. Continued use will burn out the transformer. It is humming because it is overloaded with failing components.
Jul 02, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hello! I have a Behringer EUROPOWER PMH 1000. But the power board burnt source. What do I will acquire another, or fixable?
Often teh power supply fails because of other problems. Unless the board has flame damage the parts that are defective can be replaced... Getting some of the parts that are special can take time. Most of the components are available at many sources however. The SPS400 power supply can be repaired.
Here is link to schematic that should have the SPS400 as well as the rest of the PMH1000 on it.
Jan 18, 2011 | Behringer XENYX 2442FX Mixer
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
"effects on" button stopt work after 1 houer!!!! need help
Most likely internal fuse for effects module has blown. look inside the mixer for the blown fuse (it'll be near the bit that's not working) and replace with a fuse of the same rating,
Mar 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Mar 17, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Have Beringer Europower PMH 1000
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Mar 10, 2009 | Behringer EUROPOWER EP2500 Amplifier
Can u help me
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Feb 07, 2008 | Hitachi 50UX57B 50" Rear Projection...
Car Audio & Video Logo
208 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
