Question about Coleman Powermate Premium Plus 6250W Portable Generator
It starts fine and runs on choke but not off choke
It cranks immediately; new gas, full oil. warms up nicely on choke, but the minute we take it off choke, it starts to sputter and dies. Every time.
  • 67 Answers
It sounds like you are not getting enough gas. I think it's the diaphragm, When you take it off of the choke diaphragm controls the gas flow, apparently yours is just shutting down. It's very inexpensive, and very easy to replace. Good Luck :)
Posted on Feb 23, 2009
Hi, I have a 13.5hp Briggs & Stratton motor which starts and will only run on choke slow rpms and mild smoke.
check the point where the fuel hose goes to the fuel tank
there is very fine filter in the hose that could be blocked preventing full fuel flow
only running on choke indicates insufficient fuel flow
Apr 02, 2017 | Briggs & Stratton Garden
Will not start after warmed up and sits for 5-10 minutes
Check that the spark plug is not fouled
Check to make sure your mixing your fuel
correctly & not adding too much 2 cycle oil
Adjust the idle & high speed on the carb
when you first start it up cold
Gas can not be more than a month or two old
& has to be regular 87 octane
Aug 12, 2014 | Garden
1991 F350 w/460 cu starts but runs rough until warm.
sounds like auto matic choke problem try a manual choke
Jan 02, 2014 | Cars & Trucks
Sputters and dies on cold start, significant drop in gas mileage.
You need to rebuild the carburetor or clean the choke linkage and make sure the choke valve closes cold.
Nov 12, 2013 | 1985 Isuzu Pickup
2004 eiger 400 will run about 15 minutes then sputter and shut off. let it set for a few minutes and cranks and runs fine but does the same thing all over again, i installed new gas, new carb, new fo
Check the air cleaner and any ductwork for blockage. (Mouse nest?)
Inspect the fuel system. If the fuel line is out of place and too close to the exhaust or cylinder head, the fuel may be boiling inside the line so you don't get proper flow to the carburetor (this is one possible cause of vapor lock).
Is the choke actuator part of the new carburetor? Verify that the choke is opening when the engine warms up. If it is an automatic choke, inspect the vacuum line and thermostat controlling it. Try removing the vacuum line from the choke actuator and plugging it when the engine is warmed up, then see if the engine keeps running. If it does, the actuator diaphragm leaks when the choke is open.
Check the exhaust pipe for blockage.
If the engine has an EGR system or PCV valve, check those for proper operation. If carbon deposits cause abnormal operation of the EGR valve, the engine will kill when the valve opens too much (about the time the engine is warmed up).
If everything else is good, check the exhaust manifold for blockage by carbon deposits.
Jun 12, 2017 | Suzuki 2004 Eiger 400 4X4 Manual
My lawn trimmer stalls out after running for several minutes
id Check the spark plug. If the electrode on the plug is worn , id replace the plug. Make sure you check the gap on the plug before, you install it. Id also check to see if the air cleaner is dirty, or not. If the air cleaner is dirty the engine can't breath. Is the gas old that's in the trimmer? If it is dump it out, an replace it with new gas/oil. Are you sure that you mixed the gas/oil correctly? Is there a choke button on the trimmer? Make sure that after you start the trimmer,an it warm's up a little you shut the choke back off.
Jun 01, 2012 | Garden
What should I do with my husqvarna 130BT because I put in too much oil with the gas and it won't start?
First, you need to dump all of the fuel out of the gas tank, Preferrably into a gas container. If you know how much oil you dumped in, you can calculate how much more gas to add. You could also just dump the gas, re-mix some new gas and oil, whichever you prefer.
If you are comfortable doing this, remove the fuel lines going to the carberator and let them drain into a pan. Pump the fuel primer to purge the gas out of the carburator, and then re-install the fuel lines. This might help you get it started a little faster, but its not necessary. You can burn the old gas in the engine at it will be fine.
Next, remove and replace the spark plug. Its probably fowled out with too much oil. Keep a can of carb cleaner and a small wire brush handy, you may need to clean the spark plug a couple times. If it gets too dirty, you can replace the spark plug with a new one. Do not burn Carb Cleaner in your engine for long periods of time, it will damage the engine.
After you have installed the spark plug and put some correctly mixed gas in the tank, Try to start the engine again. There will be some residual fuel in the fuel lines going to the carberator, so you will need to burn off that gas.
If you can't get it to start, try these steps:
Choke off, throttle wide open, crank several times. (or let it sit in the sun for a couple hours) (this corrects flooding)
Prime carberatur, Choke full on, throddle idle position, crank until it fires once but does not start.
Choke half, crank until it fires again or starts.
If it starts skip this step: (Choke off, crank until it starts).
Keep the choke on half for about 10 seconds and let it idle.
Put the choke off and let the engine warm up for a couple minutes.
After warmup, test the throttle to see if it will run at full throttle (it may take some fluttering until the engine is fully warmed up)
Let the engine run at full throttle for a few minutes. The exhaust may be a little more blue-smokey than normal...this is the excess oil burning...totally normal and harmless.
Mar 25, 2012 | Husqvarna Garden
What setting should it be when i begin the start process. also it seems to have a slight hesitation when i engage the trottle
Two stroke gas equipment needs a good long warm up. The heat is part of the deal. Set the choke on full chioke. Prime the bulb till you see the bulb is full. Turn the kill switch if you have one to "on" and fire it up. let it run at idle as long as it will or for a minute on this choke setting. If it dies restart and let warm up. When it is running ok but a little bit boggy then move the choke to open or half and give it some gas. If it responds then go to full open and crank it up a few revs. If it bogs or dies your unit will need service. The diaphragms in the carb are replaces as a kit and run about $6- 10. They are also easy to do if you can read and hold a screw driver. These go bad from fuel hardening every 14 months or so along with the primer bulb and hoses. Get all of this online from parts stores. Whole repair makes it like new forabout $15.00 or let someone do it for you for about $ 50.00.
Sep 08, 2010 | Homelite Factory Reconditioned 26cc...
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
757 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
