Question about Kenmore 11206 / 11306 / 11506 / 11606
Thread bunching up on bottom of fabric
When I take a few stitches, my Pfaff 1475 stalls with bunches of thread under the fabric and I have a hard time pulling the fabric up enough to cut underneath and free fabric. Then I have to cut threads and pull out all of the bits and pieces. I have tried re-threading the machine and bobbin several times, but it didn't help.
Thank you..
  • 26 Answers
With all the stuff you say I think that you should try what I do clean it with canned air. Then change the needle you may have a burred or bent needle. and when you clean the machine make sure to use a qtip with oil on it and swab the bobbin holder it may have broken needle piece stuck in it. if after that is done it still not working then adjust the tension taking care to note the positions first.make sure you change only one at a time and put it aback if it doesn't fix the problem and try another position. you may need to try the specialneedle for the fabric (stretchy or jean type)
Posted on Mar 08, 2009
Try making sure that the thread is all the way in the tension disk then test it out. I had a similar experience with an old machine.
Posted on Jul 20, 2009
2 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
Phaff 1472 stitches are bunching up underneath
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
What causes Bird Nests Superior Threads
Nov 17, 2016 | PfaFF Sewing Machines
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Sep 24, 2015 | Sewing Machines
When "locking " a stitch, bottom thread breaks and/ or bunches up.
Make sure you hold thread in back of the lowered presser foot when you begin stitching, and that the needle is piercing the fabric so that the fabric isn't slipping down into the feed dogs (under needle plate area).Hope this helps you out,alexlefebvre.Jimmy
Apr 12, 2012 | Sewing Machines
Thread bunching up on under side
try rethreading the machine top & bobbin
check to see if the thread has come off the thread take up lever
try changing the needle
also make sure the needle & thread & fabric are compatable
Mar 10, 2012 | Sewing Machines
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Kenmore 11206 / 11306 / 11506 / 11606 Logo
1,158 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
