Question about Sharp Office Equipment & Supplies
Our Sharp AL-1645cs copier shows an H4 command in the display. What does this refer to ? thank you for showing us how to fix this problem. Thanks
  • 37 Answers
The problem on your machine is on the fusing unit, the temperature in the fusing unit is low to start the machine. To cancel the trouble status follow these steps:
Press CONTINOUSLY the following:
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not do again step 1 until the display turns off.
STEP3.press 14 then press print button
The machine will now cancel the trouble status and ready to used. If not cancelled and again H4 exist it means that there is a part inside the fusing unit that is busted like the thermostat. With this you should now contact your authorized serviceman to check your machine .
Posted on Feb 27, 2009
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Jul 25, 2010 | Sharp AL 1631 Copier
H4 showing on model AL 1553
Hello my friend.
It is a fuser temperature error or one of the sensors is dirty.
You could try removing the fuser assembly - ensure power is switched off- then try cleaning the sensors as they tend to get paper dust and melted toner which collects between the surface which senses the heat from the fuser `Hot` roller.
if this doesn't fix it you may need to replace the fuser.
There is also an engineer code that you can enter to clear the fault
PRESS: Clear - exposure - clear - exposure = the LED display will turn off.
PRESS: # of copy keys until you have 14 displayed.
PRESS: Enter.
Feb 05, 2010 | Sharp AL-1553 All-In-One Laser Printer
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
H4 in the display
I found this on the web, this is for the 1631, but it may work:
It is the fuser, but sometimes it is just a false code. to reset:
enter buttons: clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it.
good luck.
Feb 12, 2008 | Sharp AL-1641CS All-In-One Laser Printer
549 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
