Question about Panasonic Palmcorder PV-L353 Camcorder
My Panasonic PV-L353D keeps turning off only with a tape in it. Other than that it works fine. How do I fix the problem?
SOURCE: Tape Jam
Can anyone give any information on this problem? I am having the same problem, on Christmas of all days. Any help would be much appreciated. Thanks
Posted on Dec 26, 2006
SOURCE: Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
Posted on Jun 13, 2008
SOURCE: CAN NOT EJECT TAPE IN PANASONIC PV GS85
you can try to pres the reset button and that my work.
Posted on Jan 20, 2009
SOURCE: check rec tab keeps popping up
Ok, I've had this issue for some time now ... and just figured it out, hopefully your issue will be the same.
If you pop out the tape you are trying to record to. Look at the top, there is a small tab on one of the corners that will allow or prevent recording on the tape depending on which way it is positioned. If you slide it open the tape is locked for recording, if you close it, you can record. Try that and see if the problem goes away.....
Posted on May 22, 2009
SOURCE: I have a Panasonic Palmsight camcorder PV-L559D
The Video Head of the camera was out of alignment. I dissassembled it and re-aligned it and now it works perfectly well.
Posted on Feb 07, 2010
Testimonial: "Excellent Solution!!! Thanks. "
Palmcorder PV-DV402 doesn't work with tape inserted
Have you tried with different tapes ? Could be that this one is binding inside, and the camcorder cannot move it. Will it fast forward and rewind ?
Jul 22, 2017 | Panasonic PV-DV402 Mini DV Digital...
Nov 03, 2008 | Panasonic PV-GS85 Mini DV Digital...
Apr 25, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Panasonic PV-DV103D
This is actually a problem with the ribbon cable. When the tape is put in and the tape door is pushed shut it jars the internal ribbon cable. Years ago I found this tip online & it fixed it!
Quote
"Ok, here goes, I had the exact same problem on my pos Panasonic pv-dv203d. After many times of taking it apart and many frustrating calls to Panasonic, I've finally figured it out, I hope it helps on your cameras.
Remove the bottom plate from the Camera (four screws, plus one near the LCD screen).
Pop off the bottom plate of the camera
Look at the ribbon cables carefully, and make sure they are all snug in the plugs. The tape transport mechanism may move them out of place."
Every now and then our will start to act up & hubby unscrews the bottom of the camcorder (Panasonic PV-DV203D), gently maks sure the ribbon cables are in place, replaces the bottom plate & it's worked for us every time. i hope this helps!
Mar 12, 2007 | Panasonic PV-DV103 Mini DV Digital...
Tape Jam
Nov 23, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
My tape player in my video camera isn't working anymore...
repairs will cost close to replacement and - it will be older ( needs new heads , probably ); buy a new one , and get a repair quote on the old one - or ebay it , for parts ;
Nov 10, 2006 | Panasonic PV-GS19 Mini DV Digital...
Panasonic Palmcorder PV-L353 Camcorder Logo
232 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
