Question about Cambridge Audio DVD55 DVD Player
I have no picture but sound on 55dvd, i have tried diferent scarts but nothing so in must be the player. it was during a dvd interactive game when it went blank but still getting sound through
Switch the machine on without a disc in and press I-scan.
This worked instantly for me when I had the same problem this week with my DVD55 i.e. we switched the machine on once and had sound but no picture. I found the following at http://www.cambridgeaudio.com customer care.
'The most likely cause of this is when the machine is set to output progressive scan. This will ussually only send a signal out to the component video jacks on the unit, and scart, svhs, and composite video will be bypassed. To return the units video output to interlace scan, press the I-scan button on the remote control.
If you are trying to turn on the HDMI connection on your DVD player, please be aware that this can only be done when there is no disc in the machine.'
Hope this helps and you haven't hit it with a hammer yet.
Posted on Dec 17, 2009
Scart in black and white
If In the settings you can select NTSC or PAL,Try changing this setting,
this may work.
Jan 27, 2013 | Philips Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
There is no sound when i play a dvd the picture is
possible bent pins on scart connector, bad lead or just not pushed all the way in. try another scart lead if the pins look good and it's fully connected.
Mar 29, 2010 | Bush DVD2038 DVD Player
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Trying to plug in dvd player and only get black and white picture. I have a Loewe Individual 26 tv
you must check for correct cable and tv input (AV1,...) then check another tv, and change the cables if necessary, always check correct TV Input.
if the dvd player is the same situation on diferent tv and cable, you have DVD Output problem. In this situation U must send to repair shop.
Note: On market has diferent kinds of cable, some better, some low quality, Check for SCART Gold Connector,( better cable with 21 shilled conductors) not the 6 conductor cable with plastic connector (low price), if HDMI cable use top shilled Cable available on the best Audio/Video retail shops.
Nov 29, 2009 | Televison & Video
Get picture but no sound
If you gettting Picture but no sound this is Normally down to a scart lead not connected correctly.
Please try pushing the scart lead in fully on the back of your Dvd player also check the back of your Tv as well. This should sort the sound problem out for you.
If for any reason this does not work then please try another scart cable incase the one you have connected now is faulty.
Hope this helps you out. If so then please leave a Thumbs up
Cheers
Little Dish Fitter
Oct 03, 2009 | Sanyo Televison & Video
I have a pioneer dvd player dv-260 and on playback there is a picture but no sound .
this maybe due to the scart lead at back of dvd
try to make sure the scart lead is pushed in dvd and tv right
somtimes u have to **** them to make a proper conection
Sep 19, 2009 | Pioneer DV-260 DVD Player
All sound but no video
it is normaly a defalt of the wii so send it back for a new one
Aug 29, 2008 | Nintendo Wii Console
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
I am not getting a picture only sound from my dvd player. What do I have wrong?
if you have connected it to tv via a scart lead, make sure it is fully in on both ends, if it is not fully in, you will get sound but no picture, failing that, try a different scart lead
Jul 02, 2008 | Philips Televison & Video
Cambridge Audio DVD55 DVD Player Logo
143 people viewed this question
Top Cambridge Audio Televison & Video Experts
Electro Med Services...
Are you a Cambridge Audio Televison and Video Expert? Answer questions, earn points and help others
