Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman 5000 that runs fine but it stops producing power after it runs for a couple of minutes.
  • tbassco Mar 01, 2009
    Thanks, checked the brushes and they were wore out, changed them and now she purs like a kitten!
  • jersey3 Mar 02, 2009
    i have a coleman 6250w generator runs great but wont put out power i have already checked brushes
  • 169 Answers
Same answer as the last time you asked, likely a flying open. If the rotor test proves that your rotor isn't opening up, test the capacitor on brushless models or the voltage regulator board on brush generators.
Regards,
Carl
Posted on Mar 01, 2009
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Coleman power ate 5000 generator, will start very easy, run for 1-2 minutes then shut down, what could be the problem?
Check oil level, and viscosity is correct 30W etc
Then check oil presure switch and wiring
Aug 28, 2012 | Coleman Electrical Supplies
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at buffalonymann@yahoo.com
Sep 24, 2009 | Coleman Electrical Supplies
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Gererator stops producing power
This sounds like a "flying open" in the rotor. Over time a small part of the wire that winds around the rotor has gotten cracked just enough to open up when it's warm and being pulled on by the force of the rotor spinning. To test this further, take the wires off the brushes and connect an ohm meter across them then run the generator, if you see the ohm meter indicate an open circuit you've found the problem. This can be repaired but it means removing the rotor and finding the weak spot in the winding. You could replace the rotor for a couple of hundred dollars or get a new generator.
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 generater-no AC output
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
268 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
