Question about Samsung CLP 300 Laser Printer
CLP-300 Printer will not print!
Like so many others, my printer just stopped printing. The LED light continues to flash red but it doesn't do anything when I send a document to print. Please help.
  • 2 more comments
  • Anonymous Feb 23, 2009
    Took the whole printer apart. No paper to be found anywhere! Unfortunately, this did not work. Any other suggestions?
  • Art Lady Feb 23, 2009
    I printed several prints, then it stopped. The status light is red. The cartridge lights scan with red dots when I reboot it, go dark, the green light goes on temporarally, and then it goes to red and sits there.
  • cyborg_811 Feb 24, 2009
    I hav a clp 300. mine was workin just fine. one day i had it 2 print about 10pgs or so. it went till 5 and then it stopped and the red light kept flashing.The guide then asked me 2 switch off the printer for about 10 seconds and try it ON.
    I tried but it still gives me those flashing red.
    Requires help.
    the above suggestion tried. coudnt find any traces.
  • Anonymous Feb 25, 2009
    It prints a few pages, red light comes on and stays on. I open and close parts of the printer and it eventually starts working again. But it's starting to get aggravating every single time I use the printer it malfunctions for 25 mins.
  • Samsung Master
  • 2,404 Answers
Check for fragments of paper inside the printer around the rollers. If you find any, remove them. Turn off the printer and then turn it back on to see if it solves the problem.
Posted on Feb 23, 2009
Samsung CLP-300 refuses to acknowledge new toner. The toner is brand new from Samsung. Test page shows the colour being used perfectly in the Samsung logo. The light just continues to flash and the...
you may press and hold the button for 5sec and let go to print the supplier info.
If it still show @ 0% you may want to check with the shop you purchase to get an 1 to 1 replace.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Won't print. status light red. yellow ink flashing . just installed the printer and haven't been able to print anything
if the problem is data just restart the printer and if the problem are the cartridges remove them all clean them and reinstall them
Sep 17, 2009 | Samsung CLP 300 Laser Printer
Printer is on idle
to detect the printer status you need to download a samsung smart panel for CLP-300 from Samsung web site.
And if the status is ok try taking a demo page by continuously pressing stop buttons till the print is out put in tray. (usually more than 5 Seconds)
Sep 01, 2009 | Samsung CLP 300 Laser Printer
Red light on and i can't print
Open command prompt and then type command "net stop spooler" and then type "net start spooler" followed by restarting your printer.
Jul 13, 2009 | Samsung CLP 300 Laser Printer
Try emptying the toner waste container. It's grey & L shaped, and can be found to the left of the blue toner cartrige. Pull it out and empty it into a plastic bag by lightly shaking it and tapping it on it's sides. But be careful or you'll make a mess. Hope this helps.
Feb 23, 2009 | Samsung CLP 300 Laser Printer
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Printer says printing but does not print
have you tried reinstallting the printer softwares??
if not try that..
Aug 05, 2008 | Samsung CLP 300 Laser Printer
Stopped printing and red light on
Check your ink levels as the red light comes on if the cartridges are low or empty and it will not allow you to print?
Dec 16, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
137 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
