Question about Samsung CLP 300 Laser Printer
Printer will not print!
Like so many others, I have a CLP-300. It all of a sudden just stopped printing. The LED light continues to flash red when you hit print but NOTHING happens.  Please Help.
  • Anonymous Feb 25, 2009
    I have the same problem, I have to pull out the inside unit with the cartridges in and then 9/10 times it will print again. do you think it could be a problem with the drum.. the whole unit which holds the 4 cartridges?
  • dollamoni Mar 02, 2009
    i have the same problem
Try emptying the toner waste container. It's grey & L shaped, and can be found to the left of the blue toner cartrige. Pull it out and empty it into a plastic bag by lightly shaking it and tapping it on it's sides. But be careful or you'll make a mess. Hope this helps.
Posted on Mar 03, 2009
I did the same with the cartridge unit and emptied the carbon out. Next to the cartridge unit. Its seems to have worked for now
Posted on Feb 27, 2009
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Printer says printing but does not print
have you tried reinstallting the printer softwares??
if not try that..
Aug 05, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-300 refuses to acknowledge new toner. The toner is brand new from Samsung. Test page shows the colour being used perfectly in the Samsung logo. The light just continues to flash and the...
you may press and hold the button for 5sec and let go to print the supplier info.
If it still show @ 0% you may want to check with the shop you purchase to get an 1 to 1 replace.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Our Samsung CLP 300 's red light stays on..
Install a smart panel on PC and see the error on the PC screen.
Oct 26, 2009 | Samsung CLP 300 Laser Printer
Red light on and i can't print
Open command prompt and then type command "net stop spooler" and then type "net start spooler" followed by restarting your printer.
Jul 13, 2009 | Samsung CLP 300 Laser Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
CLP-300 Printer will not print!
Check for fragments of paper inside the printer around the rollers. If you find any, remove them. Turn off the printer and then turn it back on to see if it solves the problem.
Feb 23, 2009 | Samsung CLP 300 Laser Printer
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
219 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
