Question about HP Compaq nx6110 PC Laptop
I have an hp laptop using windows vista and the keyboard is locked how do i unlock it ?
  • 2 more comments
  • rtupikov Feb 23, 2009
    Sorry I was not specific, it is only when I am using microsoft office, using word. THANKS
    NO, it wasn't a trial program. should I uninstall the program and then reinstall it? thanks
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you running a trial version of office and it expired? I have run into that before.
  • Ben Wabnick
    How do you know the keyboard is locked? Do you mean that your typing keys and nothing is showing up on the screen?
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
How to unlock samsung laptop keyboard
Never heard of a keyboard being locked. If you are talking about a Password, then Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 17, 2012 | Computers & Internet
Eee pc900hd keyboard lock
Hook a external keyboard to the laptop, if okay! unless you have pressed something that locked it down, the laptop keyboard will need to be changed. But if both have same problem you may have a virus, device driver issue. If mouse pad works try a system restore before this occured.
Mar 19, 2012 | HP Mini 110-1037NR Netbook
How can i unlock my keyboard?my laptop is HP Pavillion dv6940se.pls reply asap.thank you very much.
The only way to lock/unlock a keyboard is either with the Fn key and the F# key corresponding to that function. The F# key may have a padlock icon. Or if you can use your mouse, you can try going to control panel, ease of access center and click the heading 'change how your keyboard works'. I believe there are programs available which can be used to lock the keyboard, but that would likely have been installed after purchase and should have an icon in the system tray!
Mar 07, 2012 | HP Pavilion DV6940SE Notebook
How to unlock keyboard on Pavilion g6 laptop?
press the ctrl button and the pause/up arrow button - keyboard will unlock.
Dec 04, 2011 | HP Computers & Internet
Do you have a descriptions of keyboard on Windows Vista There are keys with letters and numbers with icons on them . I would like the description of the keys.
Hi.
The layout of keys can differ with different model and make laptops. The keys with letters and numbers on them are used with the Num Lock key, if you press the Num Lock key them keys will type numbers instead of letters. If you press that key again they will type letters as normal.
The keys with icons on them are used with the function (Fn) key. That means that you hold down Fn and and use the F keys to adjust things like brightness, volume, mute and Wireless radio etc.
If you are wanting a full breakdown of your laptop models keyboard then i suggest you download the user manual from HP support website. Link below.
http://www8.hp.com/us/en/support-drivers.html
Regards.
Apr 28, 2011 | HP Computers & Internet
Internal mouse will not move and lights are red/orange
this might be a problem with the mouse lock..
check ur mouse lock button just above the mouse pad.
if its locked, unlock it & try again.
if its not locked, then go to device manager via right clicking My Computer, properties
select mouse device & expand the tab
uninstall the mouse, dont worry it can be done without mouse.
now press the windows key from keyboard, and restart ur system via pressing Start key, +u, +r for windows Xp & for Windows Vista, press ALT+F4 then select restart.
After ur machine boots up, it will automatically detect the mouse & reinstall the required drivers. its done
if u like my post, pls rate me.. i really need some good ratings..
Thanks
Nov 27, 2009 | HP Pavilion dv9000z Notebook
Laptop keys locked how do i unlock them
try going to control panel>administrative tools, find the keyboard, double click it, and click "enable"
Apr 02, 2009 | HP Pavilion zd8000 Notebook
I have a HP Pavilion TX 2000, PC Tablet & the keyboard locked ((
just see the option is given on your laptop keboard for locking and unlocking .
Mar 14, 2009 | HP Pavilion zd8000 Notebook
Keyboard locked in password prompt in Vista Ultimate 64
It looks like your keyboard driver got messed up, especially if you are using a wireless keyboard or something.
Advise you reinstall vista and update the current one, that should keep your applications and files intact.
Oct 30, 2007 | HP Pavilion zd8000 Notebook
HP Compaq nx6110 PC Laptop Logo
102 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
