Question about Maytag Performa PAV2200
Water leaks into washing macine tub even when it
Water leaks into washing machine tub even when it is turned off
    Scholar:
  • 106 Answers
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares' RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites.
Posted on Feb 23, 2009
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
We get a bad smell and even after the macine stops when you turn the drum by hand you hear a lot of water sloshing around.
what you hear is liquid in balance ring that is normal.
go to appliance parts store ask for tub cleaner product
Apr 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
New LG 80490TP. Shakes vigarously while spinning
your wash load is out of balance you have to open the macine door and adjust your washload more evenly around the tub also check the floor levellers and see that machine is level
Dec 17, 2009 | Washing Machines
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Washing macine
Replace the tub seal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Leaking whashing macine
you probably have a leak high up in the machine. take the top off, wash some blankets and see if you can spot the leak
Oct 16, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Washing Macine
You have a blocked pump, tilt machine back and take pump of, it is the small thing with the black fan it is 3\4 turn to get it off, remove the blockage and you should be all good :)
Sep 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
