Question about Amana 3.2 cu. ft. Top-Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Washer didnt drain last night for the first time... I manually drained the machine and am wondering if it is the pump, motor or what? the basket still spins so I dont think it is the motor...
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Posted on Sep 04, 2011
Did you check your lid switch? i had the same problem a few years ago and the plastic piece on the lid was broken a few dollars and i fixed myself
Posted on Oct 03, 2009
    President:
  • Amana Master
  • 2,651 Answers
Well your particeluar machine has a direct drive pump so if the motor is spinning so is your pump, you can remov ethe lower acess panel and see the pump hoses right there, if you disconnect one it shouldbe apparnt as to whats happening
Posted on Mar 02, 2009
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
Whenever it gets to almost the end of the cycle and usually while it is in rinse, the error message OE comes up and it won't drain the water from the tub or go any further
Had same problem last night with my LG WM1814CW but mine didnt get to the end of the cycle, it would fill and start humming when it was supposed to be draining then the OE would appear. We drained the machine through the front door hose, turned the machine on its side and removed the drain pump. Very easy access and very easy to remove the drain pump. There was a half a bobby pin against the impeller and that stopped the turning. Took the bobby pin out and put it all back together. It works like a charm now. Very nice system that LG has.
Nov 30, 2010 | LG WM-2277HW Front Load Washer
Washer wont spin
Front load washer will not spin if the water is not draining out of the machine.
This would be the most common problem. The clean out could be cloged or the drain pump could be bad.
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water will not drain
Here is the Service Manual for reference. Sears Parts Direct for reference.
What makes you say the drain pump/line is clogged? Have you taken an error code to the display of ND for no drain? Is the machine is a FAV6800A or FAV9800A?
Is the machine failing in spin cycle of the wash cycle?
Can you supply more info regarding your no drain issue?
If there is a drain line/pump clog we would start at the Sump Cap disconnect the drain line from it and inspect the Sump Cap for debris. We would have to check if the input hose is blocked or the impeller of the drain pump blocked.
The drain pump is a tight work area I will attach a Pic of the Drain Pump location for the FAV6800A/FAV9800A machines with the Outer Tub removed. It’s located on the right side of the machine. You will see the short drain line hose from the Sump Cap to the input of the drain pump and the exit drain line clearly in this pic. But before all that I would have you place 5 gallons of water in the machine by bucket fill then turn on the drain pump in Service Mode and time the wash tub to empty the water fill about 25 seconds max. That would give me an idea if we are dealing with drain pump/line restriction issue.
Pic of the drain pump on the left side of the machine base and the motor controller on the right side……Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The water will not drain and the spin cycle will not work.
Open bottom of machine and check the drain pump to make sure it's not clogged.
Mar 12, 2010 | Washing Machines
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
692 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
