Question about Sony KP-53HS20 TV
KP-53HS20 I have this model set and was going to swap the convergence ICs. There is 15 4.7 ohm 1/2W 1% resistors going into each STK. I cannot find these resistors anywhere! Would it be safe to replace these with 4.7 ohm 1W 5% resistors? Thanks in advance!
    Champion:
  • 230 Answers
Yes you can. Just go to service menu (display-5- vol+- power) and adjust convergence settings.
Thank you.
Posted on Aug 11, 2009
Sony rptv STK chip pins making spark and smoking
replace the two convergence ICs and also check the low ohm resistors and pico fuses. You can get the sony convergence repair kit for most sony models from www.tvrepairworld.com which has both ICs 4 of the resistors and all 8 pico fuses plus instructions for doing the repair.
Jun 24, 2012 | Sony Televison & Video
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
I have a sony kp-51hw40 that I just received
This problems also cause by the 2 STK convergence ICS and some or all it resistor are dead.Require changing the 2 STK convergence ICS and some or all it resistors will solved this fading out and shuting down.
Jul 11, 2010 | Sony KP-51HW40 51" Rear Projection...
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Phillips projection tv will not converge
Replace Both convergence ICs STK392-120s use 180s better ICs they are big black ICs will have STK on them Mat Electronics for parts 1-800-628-1118.Also CK 6.8 ohm resistors around STKs.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Convergence
If you cannot align, the ICs probably need to be replaced. You can check the input on feedback resistors in front of the ICs with an ohm meter. Some resistors may be bad causing your problem. Usually you would need to replace the ICs and bad resistors and do a full re-alignment to fix.
Dec 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-61XBR200 Convergence problem
STK392-020 ICs are the convergence ICs for your model, you may also want to check the 3.5 amp pico fuses and the 4.7 ohm 1/2 watt resistors as well.
Aug 16, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Convergence
STK392-560 you will also likely need two 3.5 Amp pico fuses with the ICs you can get replacments with free instructions at the following link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS20 TV Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
