I have an HP 7310 PRinter and I wish to remove and replace the button battery. I ran across the following comment on line. My question is, how do you get to the button battery. I've already got the printer backup and working. It has a button battery that's rather easy to get too and I . . . . . . . Thank you, Henry - hjhfirst@aol.com
  • 13,433 Answers
Hey,
In order to get to the flat button batter (3volt in most cases) You would need to take printer the fully apart untill you get the board(s) out so you can get to the battery and replace it.
I've looked at the pictures You have sent us. and I don't see the battery in any of them, but I do see the mainboard, you wll need to disconnect all cables, and write down on paper which goes where.
You will need to take the printer apart to get to the battery.
this is the clearest picture I was able to get of the mainboard
I don't see the battery on this side of the board, please look it over and both sides.
The battery is possibly at another location on the printer.
I haven't been able to get a service manual for this printer so I don't have exact instructions for you. But it appears the battery may not be on the mainboard instead it can be separate at another part of the printer.
You will really need to take the fully apart as much as it comes to find the battery. Do write down on paper what goes where incase you don't have a memory of a genius :-)
Let me know if you need anything else or if you have any questions.
Thanks,
Ekse
Posted on Mar 05, 2009
    Brigadier General:
  • 3,614 Answers
HP OfficeJet 7310 All in One Printer Main Board Assembly
this a picture which you can see the actual board of the printer.
Posted on Feb 23, 2009
  • micromaster
    micromaster Feb 24, 2009
    see on the lower left corner of the main board,
    Top Expert:
  • Office Equip... Master
  • 77,499 Answers
Go to the HP web site and click support, find your printer in the lists of devices, all the info on your printer will be there as well as detailed instructions on how to change the battery, if it is not email support, it is free.
    Brigadier General:
  • 5,158 Answers
Should be a lid probably on the bottom
  • Roberta Smith
    Roberta Smith Feb 23, 2009
    it may be held on one with a screw ... the same idea as replacing a battery in a phone....
White lines across the page on pictures. Have cleaned and changed cartridges. Any auggestions?
Are these lines Horizontal ? if so, clean the roller with lint free cloth from rear end of printer ( backdoor )
From Printer Setup - go to TOOLS - You will find Clean Cartridge option - press ok
Jun 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to remove a large black line in middle of
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
A black line appears from top to bottom of paper when scanning or copying, but fine on printing from computer
Please try to do a non volatile reset.
NVM Reset
  • Remove the ink cartridges.
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
  • Insert the ink cartridges.
Regards,
Rizwan
Mar 03, 2010 | HP OfficeJet 7310 All-In-One InkJet...
When scanning or copying on the 7310 on my Mac osX 4.11 the scans and copies have large black horizontal bands across the page. The band is randomly places and. If the scan image is good, the saved PDF...
sounds as if your scanner bulb is fualty I would suggest doing a power cycle - by removing the power cord while on wait ten seconds and plug cord back in or try a different power socket (preferbly a direct socket without any adapters connected to it)
Jan 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
After changing printer cartridge, all printed pages have 3 black horizontal lines across the page about an inch apart.
It sounds to me that you need to run the clean print cartridges utility.
  1. Press the Setup button.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
    1. Open the Printer Toolbox . There are two ways to do this:
    1. Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
    1. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
    2. If above does not work, then remove the black cartridge, and olace it upside down in an area it won't be disturbed for an hour, then place it back in the printer, and print a test page. (This only applies to black cartridges)
    Oct 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
    usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
    Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    The machine is frozen, can it be fixed or time to replace?
    Hi
    We need to reset the printer, please follow the below steps to resolve the issue.
    POWER DRAIN:-
    Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
    PARTIAL RESET:-
    Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
    ----(for below reset cartridges must be removed out)---------
    SEMI_FULL RESET:-
    Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
    FULL NVM RESET:-
    Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    (Notes - resets will take a while)
    Thanks
    Riz
    Dec 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    Printer Problem
    Change the settings in MS word. Your looking for line spacing. Set line spacing to 1. Can't find line spacing? Open Help, type in the search window (line spacing). Try printing now.
    Jan 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    62 people viewed this question
    jasbo
    jasbo
