Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Dual 2 ohm or dual 4 ohm?
I am building my own system, but don't know a whole lot. I have been reading and studying, but have a question. What is the difference between a dual 2 ohm sub and a dual 4 ohm sub? My JL 6600 amp is rated at 75watts RMS @ 2 ohm. All I want to do is bridge channels 5 & 6 to drive 1 sub, but I don't know if I should buy a dual 2 ohm or dual 4 ohm.
  • 336 Answers
I would suggest you go with the 4ohm. It won't be a loud but it will be more stable. You will be less likely to blow up your amp with the 4ohm.
Posted on Feb 23, 2009
Where can I get the best advice for studying in France?
Hello, I can help you where you can get the best advice for studying in France. I also completed my higher education in France. In France, you can choose to study your bachelor's ("Licence"), masters or Ph.D. ("Doctor") degree, or participate in a summer course program, as the French educational system is designed to provide students with a wide range of study opportunities. I got these opportunities with the help of EHEF peoples. They helped me a lot. They give me best advice to build my career. if you want the best advice then contact them, I am very sure they will help you.
Feb 05, 2018 | Best Computers & Internet
Need manufacturer's support specifications
This is not that easy to take care of.
1. The building code version and requirements can be different depending on your location.
2. No manufacturer posts that information for that reason.
3. It will require an engineering study and that is required by most building codes.
4. Supporting structure may be only part of the issue, gates, alarms etc are required by some jurisdictions.
Remember that water weighs 8 lbs to the gallon and a hottub can hold a lot of water.
Apr 09, 2016 | Jacuzzi Pool & Spa
How do I get a dial tone.can answer the phone.just cannot dial out
I am NOT familiar with YOUR make and model of phone, BUT.... I've had several cordless phone systems over many years, and have had the same problem that you describe. First, here is some background info for you:
The telephone company systems USUALLY have two different dialing systems:
  1. The "old" ROTARY DIALS worked by MECHANICALLY sending out different numbers of electrical pulses which the MECHANICAL "receivers" at the phone company "Central Office" buildings would read and thus connect you to the dialed number.
  2. Some years ago, a "new" dialing system was initiated. That system was called Dual-Tone-Multi-Frequency [or for short, DTMF].
DTMF uses BUTTON KEYS which put out a different electronically generated TONE [related to] for each different NUMBER key pushed, and THAT series of tones told/tells the phone company Central Office receiver computer the number to which you wanted to be connected.
Around the world over the years, most phone companies have, and still use one of these two dialing systems, AND...
Most cordless phone manufacturers designed their phones to work WITH EITHER system, BUT....
The customer IS REQUIRED to "SELECT" which system his phone company uses, while the customer is "SETTING UP" his/her new cordless phone.
THAT process IS INCLUDED in ALL cordless phone set-up instruction packages I've ever seen!!!!!!
Either you need to carefully read and study YOUR installation-set-up instructions and then PROPERLY set your phone's dialing system [to PULSE or DTMF], OR GET SOMEONE who KNOWS WHAT he, or she is doing to do it for you.
I, and I think no one else is able to guide you via back and forth messaging on this site. At least I know I can't because I'm not acquainted with your cordless phone, AND I don't have an instruction/set-up manual to consult!!!!!
Track down your manual, OR search for a replacement manual; the dialer system selection process is NOT DIFFICULT IF you have the manual!!!!!!!
Nov 25, 2014 | Vtech CS6649 - Multi Handset Phone System
Need expedition 2007 fuse panel diagram
Ir's in the owners manual but theirs more than one plant building this truck and the panel is different depending on who built it. Canada is built different still. Alldata will sell you an online manual for your unit for a month for 10 bucks and it has everything you'll ever what to know and reading all the bullitins ( if you can stand to read that much) a whold lot of stuff you hope you'll never need to know. I read em anyway as it's why I know all this stuff. I got all cars for 168 per month. Buy enough at auto zone and they'll arrang for you to have it at a discounted rate.
Sep 17, 2010 | Ford Expedition Cars & Trucks
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
OEM vs. RETAIL OS CD
Hey Hicomp! Generally retail packaged software is designed to be sold in retail stores and as such comes with a lot of literature, extra paperwork, CD's, and usually tech support for the program you're purchasing. OEM packaged software is the same software just without the retail packaging, extra paperwork, and no tech support usually.
Mar 08, 2009 | Microsoft Windows XP Professional
Wireless 802.1 Ig network/Wap
In the question 7 of your homework? hehe
the problem is with the signal, this would work if the whole 300m was visible you could look from the other end to the other. It would work in a hall or a open space. but as there are walls in between the range doesn't extend as far. Personally I would Use 3 wireless accesspoints to cover the whole building, if there are many stores. I might need to add additional accesspoints to cover the whole building.
Question 10
I would personally choose a remotely configureable switch / hub. so if a problem came up I could connect to it from my workdesk.
Aug 20, 2008 | Computers & Internet
My printer won;t print
What type of Printer?
Feb 19, 2008 | Computers & Internet
Problems with playing discs
There are several causes for this problem.
1) Faulty DVD drive. Most drives have a dual laser, one for CD, and one for DVD. Check the player with both CD, and DVD. If it reads one and not the other, then it is most certainly a faulty laser. The laser assembly or whole mechanism will need changing.
2) Dirty or dusty lens. If the unit is kept in a dust environment, dust and dirt can be drawn into the machine by the fan. Try using a DVD lens cleaner. If this doesn't work try a CD lens cleaner. (Dual laser - see 1))
3) Condensation. Condensation can build up on the laser lens if the unit is kept in a humid environment. Also, this can be caused by a cold environment. In this case, condensation forms as the unit warms up. In either case, leave the unit in a warm dry environment for an hour.
Jan 12, 2008 | Philips LX3600D System
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
142 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
