Question about MSI KM4M-L Motherboard
Installing driver for my lan connection
I lost my lan driver..somehow..so,.i downloaded the via lan100 71 driver. I am unable to install the driver onto my computer. it is a MSI KM4M-L AMD DURON PROCESSOR AT/AT COMPATIBLE.... i have extracted this file but cannot install it
  • MSI Master
  • 3,606 Answers
Download here at MSI:
http://www.msi.com/product/mb/KM4M-L.html#/?div=Driver&os=XP%2032
click on zip file for download
Unzip the file before you install
Good luck
Posted on Oct 31, 2012
    Sergeant:
    Champion:
  • 208 Answers
Compaq Presario states the Local Area Connection Adapter is disabled
Try re-installing the LAN driver.
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jan 25, 2013 | HEWLETT-PACKARD Compaq Presario CQ5210F...
Unable to activate wireless on my HP 4520S notebook. It is enabled in BIOS + via FN & Wireless key
Go to device manager and check if the wireless lan driver is installed. If not, install the driver first and make sure you install the required software as well. (usually HP Wireless Assistant). You can download the drivers from here: www8.hp.com/us/en/support-drivers.htm.
Choose your laptop model and operating system then download the necessary drivers needed for your lan to work.
Hope this helps.
Jun 14, 2011 | HEWLETT-PACKARD ProBook 4520s
I have ADSL 2+ router D-Link GLB-802C but unable to install it what should i do.. pl.. Bhushan 9968301345
For router u did not need to install any drivers. connect the router to your PC via lan cable and check the connectivity by,
start---> run ----> cmd ----> ping 192.168.1.1
Mar 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Due to a crash, I have to re-install windows on my hp nx5000 laptop. I would use XP or Vista, it doesn't matter. I've tried to use XP again, but lost the wireless drivers to connect to the internet. Either...
IF you somehow managed to install the LAN ETHERNET connection then there is a big chancethat there is good solution to your problem.
Using your Laptop *d one dat is formatted recently*Plug in your Ethernet RJ45 cable and log on to the Internet(assuming that your Wired LAN is installed)
Download the Utorrent at www.utorrent.com and INSTALLthen go to download THIS
If you just want to download it LEGALLY then GO HERE
PART 2
INSTALL the software if its a pirated version then crack and put in the the serialRESTART program and Scan All HardwareDOWNLOAD drivers as specifiedINSTALL the drivers PROBLEMS SOLVED
Feb 19, 2011 | HP Compaq nx5000 Notebook
I have installed win xp, its unable to detect LAN connection, no icon dispays for internet, Lan cable light is coming
using another computer with internet access , you must go to the system website and support drivers tab. select your system via info requested and then download the network driver listed in the search. save this to a flash drive , or cd media and then run the application in your computer. this will allow your ethernet to function properly. this is a very typical problem when doing a fresh install with windows xp. if your display adapter settings are not correct. the problem can be solved following the same procedures and selecting the video driver for your download.
Jan 19, 2011 | Computers & Internet
Sir i lost my motherboard cd which is mercury board and by downloading of soundvgalan which are not installed in the system i used correct drivers but lan drivers are not installed because i have net...
first of all, internet does't require lan driver...... it is inbuilt in most of the operating systems..... if your lan is realtek rtl8139ethernet nic, you can download it from http://www.realtek.com/ under quick links in the right
okay???????? pls vote if you like this solution.......
Jun 26, 2010 | Biostar M7VIZ Motherboard
LOST DRIVERS
Here is the download page.
For wireless install all versions te system will use only the right driver.
Mar 11, 2009 | Fujitsu LifeBook C2340 Notebook
I'm unable to surf the web on my PC via a LAN connection to my P660HW Wireless ADSL Modem Router. I can connect and surf the web via a wireless connection on my Laptop.
Hi
Check wether the network card driver is properly installed in your computer and try to change the lan cable and check.
Jyothish
Jul 13, 2008 | Computers & Internet
Internet connection
You need to install the LAN driver for your motherboard from your motherboard CD.
Jun 23, 2008 | VIA P4X266 PE11-L Motherboard
Iam unable to install lan drivers and video drivers
I would try to go to the website of the MoBo and look for yours, you might be able to get drivers mbern
Aug 22, 2007 | VIA P4MA Motherboard
MSI KM4M-L Motherboard Logo
165 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
