Question about Brother HL-2040 Laser Printer
Nothing prints i just replaced the toner cartridge ina hl-2040 printer. Nothing prints on a page
  • 133 Answers
If you replace a new toner and sitll not working then you should push and hold on start buttom for 1 min
Posted on May 23, 2009
The printer prints every page grey and the print is lighter than normal. the toner light is not on. should I replace the toner cartridge?
Your problem sounds more like a bad drum unit than a toner issue. You should try cleaning the corona wire first which you do by removing the drum/toner unit and looking for the little sliding blue tab. Move this back and forth a couple of times and then reinsert the cartridge and try printing again.
Sep 06, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
New Toner Cartridge Does not Print (HL 2040)
hi!  have you check you toner, it has a white strap, you need to strip it to open the nozzle of your toner. but before you do that you need to shake it first to have a sharp print out before you would strip that white strap. have a nice day
Dec 20, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 won't print
Sounds like the toner cartridge is faulty. I would change the cartridge.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Toner
You could try two ways.
1) reinstall the software.
2) push "start" buttom for 1 min
Sep 16, 2008 | Brother HL-2040 Laser Printer
HL-2040 prints fading images
this is the problem of scanner assebbly (lense section), So open this section & clean the scanner after that your printer will work properly.
Feb 13, 2008 | Brother HL-2040 Laser Printer
HL-2040 Almost black Pages
Drum needs replacing, normal consumable, possible faulty toner hard to know when you use non gen items.
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
