Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote doesn't work, after changing the battery
I just changed the battery on my remote for my garage door and now it doesn't work.
Help me please
  • 118 Answers
Reprogram the remote. Press the learn button on the back of the opener and then press the remote button until the light on the opener blinks once.
Posted on Feb 26, 2009
5 Suggested Answers
SOURCE: Garage Door Remote Not Working Consistently
Had and still have the same problem. Sears refuses to fix, but acknowledged that the problem is caused by rf interference with their 315 mhz frequency use by motion sensors, etc... They will not post this on a web site or any advertisement. They will not put in any manual, nor do they have any fix. I took off and threw out a motion sensor on my light and innitially fixed the problem. I recently installed a water fountain bird bath with six small LED lights in a front garden, which shut down my remotes AND my home links in my cars. The probl;em has been isolated to the LED lights! Sears advised that Chamberlain makes their garage door openers. Chamberlain blamed the water fountain manufacturer. Both refused to fix. I am switching to a Genie which operates at 390 mhz.
Posted on May 17, 2008
  • 3197 Answers
SOURCE: Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Posted on May 12, 2009
  • 3197 Answers
SOURCE: Recode a Linear LDO33 remote
Go to this site which is a pdf file and follow the instructions "To remove all controls." That will do what you want.
http://www.linearcorp.com/pdf/manuals/LDO_user.pdf
Posted on Jun 27, 2009
swolfinor
  • 504 Answers
look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 29, 2010
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
May 21, 2016 | Building Materials
How do you reset an ATA TXA1 Garage roller door remote opener, can the code be changed
heeeeelllllllllo......go to youtube they have the demostration............tkx....g.scott
Jul 15, 2014 | Chamberlain Universal Garage Door Opener...
G3T-BX
check manual for erasing codes and reprgraming remotes should be something about a learn button
Oct 21, 2012 | Genie G3T-BX Keychain Intellicode Garage...
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
892 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
