Question about Lexmark 4227 Matrix Printer
Lexmark 4227 Plus Matrix Printer on Vista
Hi
I cannot print in Lexmark 4227 Plus dot Matrix Printer using Vista, while I can using XP. Any ideas to solve the problem?
Is there any available driver on the net?
Thanks,
George
    Genius:
  • 2,035 Answers
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step Action Click on Image 1 Click on the Microsoft logo start button. Lexmark 4227 Plus Matrix Printer on Vista - pattlnk_3212007_1551-vistastrtsm.jpg 2 Click on Control Panel. Image 3 Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon. Image
4 Select Add a printer.
Click for Image 5 Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
Image 6 Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
  • Stop Search - Select this if you can identify your printer prior to search completion.
  • Search Again - If your printer does not appear,determine whether the printer is on the same segment of the networkand confirm successful communication with the printer.
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
Image 7 Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
Image 8 Observe Detecting the driver model...
NOTE:
Image 9 The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer. Image 10 Observe Installing printer... Image 11 Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
Posted on Feb 23, 2009
How do you change a printhead on a lexmark 2381 printer
throw it in bin they not easily fixable
buy a better one with cheaper cartridges
May 05, 2016 | Lexmark 2381 Plus Matrix Printer
PRINTS TO SLOW
Dear...
1> Use the properties section to check the speed settings in the driver and try again.
2> Printhead alignment checked.
3> Has someone changed the setting on the printer to Print "Best Quality" instead of normal?
4> Finally Full servicing Lexmark 2380 Plus Matrix Printer.
thanks...
Feb 15, 2013 | Lexmark 2380 Plus Matrix Printer
Can;t find a diver for my lexmark 2390 plus 4 windows 7
Your printer is not compatible with windows vista or windows seven and no drivers have or will be available for it, sorry
Mar 30, 2011 | LEXMARK 2390 DOT MATRIX PRINTER REFURB p/n...
Network printer printing rubbish when printed from Vista
The problem with dot matrix printers is that these are very old printers and you may not find a printer driver for them that run with Vista. If the incorrect printer driver is installed, the printer will print rubbish.
The only suggestion I can offer is to try various generic printer drivers until you find one that works. Connect it to the LPT1 printer port first and when you get it to work then set it up on the print server.
Also try Panasonic support and ask if they have a printer driver for this model printer that works with Vista.
Oct 22, 2009 | Panasonic Office Equipment & Supplies
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
The check light is on very faint all the time and cannot clear paper jam message.
Please call into our technical support team its free as long as parts are ordered thru us.
Thanks,
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 02, 2009 | Lexmark 4227 Plus Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
Hi and welcome to FixYa,
It would seem you posted twice.
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
Lexmark 2390 Plus Owner's Manual
Hi, I hope the document in this link will be helpful for you. Apparently these printers are no longer sold, acording to the Lexmark site search, nor do they have the manual in their Support area.
It seems you need a serial adapter cable to connect. It is a very concise PDF document about your printer and well worth keeping I think.
Let me know how you go
SeaJade
Nov 20, 2007 | Lexmark 2390 Plus Matrix Printer
Lexmark 4227 Matrix Printer Logo
328 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
