Question about Kenmore 22422 Top Load Washer
Series 90 110.92093120 how to remove cover and not spining
Need to now how to get the housing off to get to the area to fix & find out why it is not spin and is there a blet drive type
  • 50 Answers
Is it agitating and pumping out?
Posted on Feb 26, 2009
How to access behind the dryer drum
Hello. I don't have the make/model number but I'm going to attempt to help you! Assuming that the dryer has the top mounted lint filter, the blower housing cover will have 2 screws which attach the blower housing to the top cover visible when the lint filter is removed. You must remove power from the dryer to proceed. The tool has fallen into the blower housing where the blower fan is located. The vent tube must be removed(pipe that attaches the dryer to the wall). Next, the rear cover of the dryer must be removed to expose the blower cover, usually mounted on the left side( if you're facing the rear of the dryer). Remove the 2 screws from the top of the dryer(underneath the lint filter), next, remove the 3-4 screws which hold the blower cover onto the blower housing. Usually, in order to remove the blower cover and access the fan area, it will have to be firmly pushed upwards and at the same time, pulled outward at the bottom to clear the bottom lip of the dryer. Vacuum out any debris inside the cover and fan, remove the lost tool, and then(and this can be a pain to do) replace the blower cover. Be patient(you have to slide the cover up, back into position and push firmly in order to get it to go over the bottom lip of the dryer again. Be careful! There are many unfinished edges in dryers and it's like putting your hand into a box of razor blades when handling parts such as these) Replace the mount screws of the housing cover and rear cover of the dryer.(Positioning of the rear dryer cover can be tricky to get the screw holes to line up again--the rear cover has a lip beneath where the vent pipe is located that sits on an edge--it sometimes can be difficult to get positioned properly so be patient and don't get frustrated!) Once you get a couple of screws in, the rest should line up reasonably. I hope I helped you!
Dec 19, 2015 | Washing Machines
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Spin cycle makes jet airplane takeoff noise. assume main bearing on spining tub is out. What part replaces this bearing? Diagrams do not mention bearing!
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
Jun 04, 2011 | Maytag Neptune MAH6500A Front Load Washer
I have a bosch 300 series front load washer that wont spine it fills and drains fine belt is on what could it be
If it doesnt wash either, the brushes will possibly be the problem. You need to remove them and check the length.
Aug 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Admiral designer series, heavy duty 20 lb washer.
If one end of the motor is connected to the drum of the washing machine that is where your problem lies There is a gear inside of the housing connecting the motor to the drum i.e. transmission, this gearing is plastic and does easily break when a heavy load is done based on age of unit. What you need to do is seperate the motor from the tub. There should be a rubber boot that slides off to expose the gearing .. This gear will probibly look like a round piece of plastic about 3 inch in diasmeter once you get to the gear you will need to remove both sides of the gear. If at all possible do not remove the metal cover on the motor side of the device if needed to remove there is oil in that area so be careful you dont spill it all over.. If you need to remove this cover drain the oil first. Part can be purchased at any appliance warehouse trake the model and serial number of unit with you Good Luck
Dave
Jul 20, 2009 | Admiral AW22 Top Load Washer
I have a 8100 series washer that creates to much lint on the clothes and i'm not shure if there is a filter for lint or how can i overcome the excess lint.
The Soloution is to remove the bowl and clean the slinger underneath the bowl.
there is also a build up of lint that stays in between the main bowl and the outer plastic bowl
this requires cleanining as well. in order to remove the bowl you wil need to do the folowin.
1. remove the two screws at the front that hold the control panel.
2.remove the two clips that hold the back cover fixed to the front lid and housing.
3.take away the front housing by tilting away from the controls.
4.remove the agitatator top plug by pulling upward.
5.there is a 7/16 hex head screw that needs to be removed here to remove the agitator.
6.remove the round lock nut from the bowl this can be a bit difficult depending on the corrosion of the nut, I had to make up a tube spanner to to remove the nut counter clockwise.
7. as you will se over the years there is a lot of build up.
hope this helps.
Chris Ficior.
Jan 17, 2009 | Washing Machines
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
I have a kenmore calypso elite washer. It stopped in the middle of a wash and displayed the message "Ld". I assumed that meant that the load was off balance. So I redistributed the clothes and...
lean washer back remove bottom cover have towels handy remove bottom cover on pump (if it has them) clean pump..if it doesn't best replace pump older pumps had spines that would strip out so pump would pump out the water
Sep 07, 2008 | Washing Machines
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
