Question about Kenmore Dryers
Old model Kenmore stackable washer & dryer,dryer is dead
I have an old model Kenmore stackable washer & dryer, about 10 to 15 yrs old. The washer part works but the dryer part is dead. It's a Kenmore All in one stackable washer and dryer. They are not separate but permanently attached. I believe the model to be 417, it looks just like it. There are no numbers on the machine itself. Can you help me?
  • 11 Answers
SOURCE: How to seperate a Kenmore dryer from the washer under it?
This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine.  Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings.  Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
Posted on Oct 12, 2007
  • 958 Answers
SOURCE: 1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Posted on Feb 25, 2008
SOURCE: Stacked SEARS DRYER MODEL NUMBER 417-82142101
with 2 people. There are 2 white caps towards the bottom of the dryer hiding 2 screws. remove the screws and tilt the dryer back about 2 inches, while tilted back pull the whole dryer foward and it will free the dryer from the brackets in the back.
Posted on Oct 31, 2008
  • 7 Answers
SOURCE: asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Posted on Feb 25, 2009
  • 25 Answers
SOURCE: Kenmore washer dryer age?
Next to the serial number there should be a manufacter date. that is when it was made. I am guessing 2 years old.
But check on the back, it is peobaly printed on a small metal tag.
Most electronics have a manufacter date posted on them for warrenty sake. yours may still have a warrenty. you can also go to Kenmore website and in the search area type in the serial number and it can tell lots of info including if it is still under warrenty. wouldn't that be a nice surprise!
Posted on Jul 26, 2009
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Mar 12, 2009 | Kenmore Washing Machines
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
