Question about Samsung CLP-500 Laser Printer
Waster toner tank full/not install
Waste toner tank full/not install" I have dumped the toner tank and wiped it clean but the printer is still saying "waste toner tan full/not install"
  • Anonymous May 07, 2009
    is it easy to find the sensor as I have washed the tank several times but as soon as i put it back in I get the usual message
The Waste Toner Cartridge must be VERY clean, especially around the "bump" directly below the left side hole. After I CAREFULLY emptied the old toner out, I used air compressor to clean every bit of toner out from inside. Then I wiped the whole area around the "bump" where the sensor "sees" if the tank is empty. Even a slight film over the area will not allow for reuse. If you do this, it works every time.
Posted on Apr 06, 2009
  • 3 Answers
U need to open the printer and make sure the sensor is clean then u can clean up your waste toner tank and put it back, it must work
Posted on Mar 04, 2009
  • 50 Answers
You have to make sure it is very clean. If there is any toner near the sensor, it will detect it as full.
Posted on Jul 24, 2009
I've replaced the toner cartridge and waste toner bottle, but the display still says 'toner low' and 'waste toner near full'. It refuses to print, even with the old cartridges.
Then you mite want to clean the sensor that monitor the waster toner box pull out the waste toner box and look for the area that show clear plastic then look for those area of the machine and blow the old toner from those areas waste toner mite have gotten on the sensor saw they can not see the clear plastic and think that the waste toner cart is still full.
Sep 09, 2014 | Konica Minolta Magicolor 5670EN Color...
What is the waster toner container
hi,waste toner container is the printer after the printing balance taransferbelt toner image is wiping & then store the printer tank this is the waste tank or toner waste container
Mar 13, 2014 | Samsung CLX 3160fn All-In-One Printer
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Nov 17, 2010 | Samsung CLX 3160fn All-In-One Printer
Xerox work centre 7120 message say change waster toner, I found where it is but how do I change it
You can either dump out the waste toner into a garbage bag, or replace the whole toner collector. If you decide to dump it out yourself, you need to make sure that the container is extremely clean prior to reinstalling it into your copier, as sensors on the copier end detect the level of used toner by optic sensor.
-David.
Nov 03, 2010 | Xerox WorkCentre M-24 Color Copier
My samsungclx-3160 all in one is asking me to replace/install waster toner tank?? it wont print now whats that
The waste toner tank may be full. Please open the front cover( where the toner bottles are located).
You will find a transparent "L " shaped box is the waste toner tank.
You may pull it out and replace it.
Oct 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Jul 21, 2009 | Samsung CLP 300 Laser Printer
Printer not printing
On the machine there is a sensor that looks trough the waste tank even though you have wiped it clean the likely thing is that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
Hope this helps you
Thanks J
Jan 05, 2008 | Samsung CLP-500 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Waste toner tank full/not install keep displaying
The sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay. Otherwise, the sensor may need to be replaced by an authorized Samsung technician. Let me know how it works out!
Jun 16, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
944 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
