Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Output color problem
Copier is working properly bet the output quality is not good.
please help for working the quality.
    Sergeant:
  • 199 Answers
Try to off toner save mode
to press * printer setup - print quality
and adjust print density also in the menu.
Posted on Feb 26, 2009
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Copier stopped printing in color, at which time I installed a new color cartridge in an attempt to correct the problem. It continues to only prints in black and white.
Hi
Please go to printing preferences and uncheck the print quality greyscale quality. Then try to print again.
If not working, please let me know to help you more.Regards
Mar 03, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Brand new printer photos look bland and"unsharp"very dull color checked color shades but not using brother paper does this matter?
Make sure the cartridges are proper and there is no dust on nozzle just clean with tissue paper and also use brother photo quality paper that is special type paper use that.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Brother Dcp395cn InkJet Printer
I have a Gestetner DSC232SP color copier. It is producing horrible color copies when it was doing ok before. The copies are coming out with many white lines through them and many color faded and brights...
It's always a good idea to clean the drum and corona wire when changing toner cartridges. Sounds like a dirty drum is the culprit here and a thorough cleaning will return your copy quality back to where it belongs. It's also a good idea to gently shake the toner cartridges from side to side before installing them to ensure even distribution as toner tends to settle while being stored prior to it's initial installation.
Dec 04, 2009 | Gestetner DSc232sp Copier
I am using Toshiba e-studio 166. When i print say 10 documents together, at the output there are more than 15 papers i.e. 5 are unprinted plain papers come out stuck together in between. Please advise your...
Toshiba has extraordinary fingers and rubbers for paper pick up, so I assume that paper is the main problem.
Every time when you need to put paper in drawer you should shake a little bit (depends on paper manufacturer if they don't cut paper good they are connected with small tiny pieces of paper).
Also if paper is wet they will cause issues. Keep paper dry.
I hope it helps
Oct 31, 2009 | Toshiba e-Studio163 Copier
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
My colored ink does not work even it displays high amount of it
Go to Printer and Faxes, right click on your printer, select properties. general tab, printing prefrences, paper quality, select color.
I hope this helps.
Good Luck.
Mar 14, 2009 | Lexmark Z640 InkJet Printer
Color problem please help
Did you just replace the toners? are you using generic? I have seen some colors off due to generic toners, (could be a bad batch).
Also, there should a be screen in the Menu section where you can try adjusting the color or
Re-calibrate it ( I would try this 1st)
Print out a Demo sheet it will give you a color test sheet how does it look?
I am not a color copier specialist but have worked w/techs that are, but i work on color printers, ususally same principle.
Also look for a screen called Configuration page this will tell you the settings of the copier and may actually tell you if a color is off.
the problem is you have to have a service manual because you are dealing with adjustments on an X-Y plane.
Nov 20, 2008 | Office Equipment & Supplies
No color output
Here is a link to the service manual, look at page 2-13, you can do the Print quality checks.
http://www.eserviceinfo.com/downloadsm/21711/Lexmark_x5150.html
Click on the link on the web page that opens up, it's about 1/3 up from the bottom of the page.
Download >> To download the file, please, click here ! << Download (<do not click on this link in this message)
Please remember to rate Techs who assist you for free :) Good luck, Joe
Sep 30, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
49 people viewed this question
old marine
old marine
