Question about Spark Plugs BR4HS Plug 10/BX #3322
How to replace hyundai entourage spark plugs?
Spark gap for 2009 hyundai tucson 2.0 litre
The Manual says .044inch, Some plug makers advise not to change there preset gap. Most plug charts recommend the gap for most makes and models.
Oct 18, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
How do i remove a stuck spark plug wire on a 2003 pontiac grand prix
You will have to replace the wire. Pull old one off remove spark plug pry the metal end of the wire off the spark plug. Replace spark plug install new wire. there is anti stick for spark plug wiring I would use if I was you
Aug 07, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Hi , I have a problem . Hyundai getz 1.3 the car has a mis / flatspot. I have replaced plugs because I noticed oil on the electrode of the plug.the car was fine for a week and the problem the reoccurred. I...
have you changed the plug leads. or the ds pack some engines have leads or a dispack. dispack the seals can go and cause arking. leads weak leads will sort out in them self and moving them about can reconect them. if they have gone hard they should be changed as that means they are brital.
Sep 29, 2013 | Hyundai Vehicle Parts & Accessories
2007 Entourage AC Not Working, Check Engine Light On
Well you know where to start
You have a check engine light & if you
did not,you still check for codes & then go to
enhanced codes & body functions & A/C module
Without a factory diagnostic manual & service work
book to learn the system your done,even so for a dealer
or shop
Have to have that info
Not my place to ask who has worked on it
& what your plans are to resolve
Jul 26, 2013 | Air Conditioning and Heat for Hyundai...
Poor heat 2008 entourage
Bad or No thermostat at all, low coolant, heater core going bad...
Feb 17, 2013 | Air Conditioning and Heat for Hyundai...
Which fuse is trunk light fuse for hyundai entourage
In the rear area module, check the 7.5A LUGGAGE fuse.
Sep 26, 2012 | Hyundai Vehicle Parts & Accessories
Does the 2004 hyundai xg350l use spark plugs or something els
yes the xg350l has a 3.5l v-6 engine that uses spark plugs
May 01, 2012 | Hyundai Vehicle Parts & Accessories
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
150 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
steve morris
steve morris
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
