Question about Electrolux Vacuums
Over heat light
My electrolux super j seems to over heat//the light comes on//new bag and rear exhaust filter are new and doesn't fix the probem // I was told maybe it needs a new hose ??????
  • 76 Answers
It is one of two problems the hose or attachment's are plugged up some or the motor is getting bad. So check the hose and attachment's if they are not plugged up and it is a motor getting bad.
Posted on Feb 25, 2009
How to fix
The machine may be over heating.Check the hose and power head for a block.Or,put in a new bag and suck in a few pieces of tissue to coat the lining of the bag....Chris
Aug 01, 2014 | Electrolux Epic 6500 Vacuum
Cannot find filter in bag compartment
If you're looking for the exhaust filter, it is on the top of the machine under the crevice tool and dusting brush.
If you look at the rear of the machine you will see a tab on the attachment holder.
Remove the attachments on the unit
Push tab on rear of vacuum on the attachment compartment
Lift cover and your exhaust filter should be exposed and should just pop right off for replacement.
Mar 03, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Full bag light on when bag is new
Check for secondary filter, if it is clogged could cause bag light to come on as suction is dropping due to filter, not bag.
Dec 08, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Mar 10, 2009 | Electrolux Epic 6500 Vacuum
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux renaissance bag is light and vacuum stops and the change bag light comes on
Mine is doing the same thing, well it was. I sat it upright and it seems to be working fine... there is no blockage in the hose, the bag is clean... only thing I can't change is the filter. Maybe that is the problem, it doesn't seem really dirty though. I'm thinking perhaps the unit was too hot, hence having to be turned up right... makes it a little harder to move around but it is running at that is all I care. Hope this helps
Aug 29, 2008 | Electrolux Vacuums
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Unit will not run
I DON'T KNOW WHAT YOU MEAN BY "F/C" LIGHT, BUT IF THE MACHINE IS OVER HEATING THE LIGHT LOOKS LIKE A THEMOMETER. IF OVER HEATING IS THE PROBLEM, ONCE THE MACHINE COOLS IT SHOULD WORK AGAIN.
Aug 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
