Question about Hoover Vacuums
Hoover Tempo Vacum Cleaner - 2yrs old. Just stop working. Checked all recomanded steps in manual. Looking for a location of fuse within appliance to reset.
  • rkm_shah Feb 26, 2009
    Thanks for your suggestion. I will check for loose connection at the switch. It is quite possible since I plugged several times and occassionaly a short burst of motor and then stopped.
    Once again thank you for your suggestion.
I had a panasonic with the same issue. Turned out to be just a loose connection at the switch.
Posted on Feb 25, 2009
Height adjustment doesn't adjust work. Vacum Too difficult to push.
Are you Missing the Front Wheels under the Vacuum? This asswmbly can fall off
May 25, 2016 | Hoover Tempo Widepath Upright Vacuum -...
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Is there a reset button on the hoover tempo widepath. I plugged it in and the on/off switch was ON, it sparked at the wall and then stopped working. Will not turn on at any wall plug in. Hoping it needs to...
canot see any mention of reset swich in manual, try renuing the fuse first, if it still does not work change the plug.cutting the cord back about 3 inches,if still no luck have it looiked at by your local repair shop.
Aug 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
My Hoover Turbo has the power and motor works well but there is no suction power. I have taken all steps to ensure that there is no blockage in the pipes. I live in the Benoni area and would like someone...
remove the screws from the funny looking thing on the back (about 10 philips head screws) and remove the blockage from the big hose. Don;t stop working on it until you are absolutely certain there is no blockage. You may need a long screw driver and maybe another smaller vacum to help get the stuff out. I have the same machine and had the same trouble.
If you want to prove or disprove blockage as the trouble, remove the handle and listen to the motor.
Sep 21, 2009 | Hoover U5396-900 Turbo Power Vacuum
Fuse auto shut off
Find the current rating for the vacuum cleaner motor (on a plate somewhere on the machine). Is it somewhat less than the breaker rating in the panel? If so, then either the motor is overloading the breaker due to bad bearings or a shorted winding in the motor or the breaker is failing. Check the current draw of the running motor with a clamp-on ammeter (a friend with one or an electrician). It should be close to the rating on the plate. If in excess, then the motor needs to be repaired or replaced. The motor normally works harder when it is pulling full vacuum--it speeds up if the air flow is plugged.
Sep 08, 2009 | Hoover S5620 Vacuum
Need a front wheel assembly for my Hoover Tempo model u5144-900. I see similar looking Hoover wheel assemblies online for different models, will they fit mine?
The Tempo series cleaners look similar, but are different colors. The wheel assemblies will work if they look identical in appearance to yours.
Aug 07, 2009 | Hoover U5144900 / U5146900 / U5147900...
Vacuum not working
Enter "Tempo" into the following location bar once you get to this link:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
There are a few different models including bagless and bagged versions of the Tempo of which you should be able to find any one of the pdf. adobe files.
Good luck and don't forget to rate.
Mar 27, 2009 | Hoover Tempo Widepath Upright Vacuum -...
I was given a Hoover model 450 vacum cleaner i am looking for information aout this product
Go to www. hoover.com, you can download user manuals if it is available. Make sure that you have the correct and complete model number.
Jan 11, 2008 | Vacuums
Vacuums Logo
100 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
