Question about Capcom Resident Evil: Code Veronica X
I am stuck in a room with 6 pictures on the wall. i dont no wot to do
That one is a brain teaser. the solution is that you must correctly place them in order from the oldest ancester which is veronica. then comes the man with the red headed twins,the babies.after him comes the red-haired man with the teacup, his son. Then comes his brother, the other red-haired man with the white plate in the backround.Then comes the man with the earthenware vase in the backround. Last comes the man with the white candlestick. Good Luck on the rest, you'll need it!
Posted on Mar 02, 2009
What's the perfect combination to decor the room?
Room posters alone may not be very much entertaining as much as decorated rooms add life your overall environment. But, interior designers think that the perfect combination of an awesomely arranged interior design is to make a perfect combination of decorated rooms and posters. Visualize! How things seem to be in the presence of only a room poster. Moreover, if a room is decorated, without having a poster on its walls, it would give an incomplete look. Therefore, the best part would be to make a combination of decorated rooms and room posters. For instance, if you are having a red-colored entirely decorated room with a perfect combination of a poster on all its walls, what a beautiful look it would give to you and your guests. So, what you have to do is to go for artistic room pictures or Wall posters in order to decorate your rooms in a perfect way.
Sep 20, 2015 | Canon PosterArtist 2008
I have a 1996 jeep grand cherokee limited 4.0 straight 6 and every once in a while it seems to want to stall and dose at times. i have replaced distrubter cap, rotor,coil,plugs,and wires and it still has...
answering for USA not export model.
great question and is now tuned up, scratch off top contender, yes.
stalls, are cause by 6 reasons in physics, or 50 parts, fails.
lets work the 6, mo easy.?
but ill pause now and do my 20 questions,(sorry, i cant see all)
I'll assume those spark HV wires are put on one by one and not scrambled. and gaped to spec? (under hood spec. sticker?)
Does the CEL glow just before the stall? or with scan tool attached
does it log (store) DTCs at stall or near?: use a scan tool and win.
they can be had for 10 bucks, (elm327)
  1. can you save the stall fast right foot actions?
  2. if yes, can you do it with tiny foot or huge (takes near wide open throttle to keep er' going"
  3. if stalled does it restart fast or take or take, wot FOOT ACTIONS. YES ;/NO OR WOT WORKS.?
  4. if it dont start, does the classic, spark test x6 pass muster?
  5. when it starts after stall, got black tail smoke, or stinks of raw fuel?
  6. lets now say all above passes, so why does it want to stall.?
  7. easy, IAC stuck closed, ! #1 cures that temporary.
  8. EGR if you have one, stuck open ,many dont these years.
  9. it stalls for lack of air, IAC or is flooding, what I do if i can make it stall on demand is let it and read the plug tips. oh my #6 is soaked, and #6 injector leaks. (evidence)
  10. Say its too random and hard to trace. easy. sure.
  11. what are all cause, easy, there is a list.
see the 6 ways here (it's really 5)
and the 18 line item failures. (lacking the symptoms alluded to above)
cheers !
Dec 28, 2014 | 1996 Jeep Grand Cherokee
What is the square root of a room that is 30 ft long by 10 ft wide by 6 ft walls
A room doesn't have a square root.
Are you asking for the diagonal of one wall? Of the floor? Of the room?
Dec 05, 2011 | Office Equipment & Supplies
Not cooling 110 sq ft room
The smallest retail AC unit will cool down a 110 sqft room if...
1. It is installed in a way as to dump heat outside... 2. There is actually cool air coming out of the AC (it is working)... 3. The windows and doors are tightly closed... 4. There are no major drafty leak issues (i.e. hole in a wall)... 5. You're not adding substantial heat energy into the room (such as having 10 sweaty fat men eating food while watching Super Bowl on a 56" LCD TV)... 6. The room has at least minimum insulation (the walls are not just plywood)... Seriously, if HEAT is leaving the room by way of the AC, the room temperature HAS to decrease, unless HEAT is being added back into the room in some way. This is basically the 1st law of thermodynamics.
Jul 24, 2011 | Heating & Cooling
I have a samsung ps50c7000 and a c5900 3d blu ray player. wot is the best home cinema/speakers to contact this up to as all yhe kits *** with a blu ray player that i dont need. i was going to go with a 2.1...
I would recommence the BOSE Cinemate II. It is 599.90 has an optical in or an analog in, You would want to use HDMI from XBOX to tv, and from bluray player to tv using HDMI, Then optical cord running from TV to Cinemate.
Feb 14, 2011 | Samsung Audio Players & Recorders
I need to replace some old storage heaters in my
you need to measure the height of celing size of room how many outside walls thickness of walls take this info to your local heating shop they will tell you the heat loss for each room and what size heating you need in kws you then choose the heaters you want
Apr 19, 2010 | Heating & Cooling
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
Place unit on level surface away from direct sunlight.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Printer will not turn on
Mine would not come on eather I have a hp 7210 all in one. I read some where someone unplugged it and held down # and 6 and plugged it back in while holding the buttons. It did'nt work for me but I unplugged mine from the wall and plugged it in across the room and mine came on.I dont know if holding the buttons down worked or not but try it any way.
Apr 27, 2008 | Office Equipment & Supplies
Tv problem
Are you still willing to fix your set? I can help....T.
Oct 02, 2007 | Toshiba 42H81 42" Rear Projection...
Capcom Resident Evil: Code Veronica X Logo
284 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Piyal Perera
Piyal Perera
Person On the...
Level 1 Expert
Tre Elkins
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
