Question about Smith Corona Wordsmith 200 Typewriter
File? 12345678
With that message I can't type anything. What can I do? What has caused this to lock up my typewriter?
  • 45 Answers
Is the typewriter a Smith Corona SD 250? If so, you have entered the "memory" mode by mistake. Over on the left side of the typewriter is a switch marked "MEM", "LINE", and "TYPE". Move the switch down to "LINE" or "TYPE" to resume normal typing. DO NOT PRESS ANY NUMBER BUTTONS ON "MEM" MODE! Does this information fix your problem?
I just got this typewriter a few days ago so I don't know everything about it yet... But I believe that this is one way to fix your problem.
Best of luck to you!
Posted on Jun 07, 2009
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Olympia compact typewriter need manual and it locks up all the time
Go to NADIST.COM click on current models on of them may be the same as yours.
DickyO
Mar 14, 2012 | Olympia Office Equipment & Supplies
When you try and type all Caps it types anything but the key you hit
Check to see if the pitch selector is in PS this will cause wrong printing. You might also check to see if you are in KB ii Code 5
DickyO
Jan 21, 2010 | Nakajima AE-710 Typewriter
Samsung i780, forgot password.
Alone, You will have to get the firmware re-installed to be able to use your phone. And remember that there are no magic keys that can open any and all locks.
Aug 08, 2009 | Samsung SGH i780 - Microsoft Windows...
IBM Wheelwriter 6---when I turn it on, it appears to lock
There are a few possibilities. First lube the silver shaft that the carrier slides on (WD40 works well). Remove the printwheel and check for paper or ither debris in that area. After that you e
will probably need a tech.
DickyO
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
Swintec 2640 access to stored files
check your manual, for future reference, always keep trying until you get ahold of the tech. that worked on your machine. a good repair shop always guarentee's their work, and will be happy and in the best position to help you
Sep 11, 2008 | Office Equipment & Supplies
Corona smith premiere 100 typed writer
El problema de tu Maquina es que tiene un Censor de Cubierta Abierta en la esquina de carro impresor lado izquierdo y esto no esta conectado o no lo esta oprimiendo la cubierta cunado la cierras , revisa esa area
Apr 22, 2008 | Smith Corona Wordsmith 200 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
78 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
