Question about Nikon COOLPIX L18 Digital Camera
My screen is black or blank
Everything works but my screen is black. My shutter opens when I turn it on. I have a coolpix S1
  • Nikon Master
  • 4,738 Answers
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jun 12, 2009
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
When the camera is on the screen is blank/black as if shutter is closed (it is not). i've tried changing the settings but that didn't help. any ideas what the problem could be?
CCD FAILURE !
Just Call Nikon they will do it FREE OF CHARGE ! ask them about BAD CCD !
it is a known manufac fault and all are doing it FREE !
Pls rate me WELL
Jul 15, 2009 | Nikon Coolpix S1 Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Whenever i want to take a picture the screen reamins black
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Black screen
OK, this might sound stupid, but I had the same problem with a similar camera and I had accidentally pushed the Display button. I was about to give my camera up for dead. Try pushing it (the little button on the bottom back that says Disp on it). Does that bring your image back? If not let me know and I'll research further.
Jul 13, 2008 | Nikon Coolpix S1 Digital Camera
Nikon coolpix s1
Replace the Camera.
This is a mainboard problem- possibly only a connector worked loose
Sometime gentle squeezing of the camera cace at the base under the screen or gentle slapping in the palm oh hand may induce a re connect.
But essentially this is not going to get repaired
Jan 24, 2008 | Nikon CoolPix S2 Digital Camera
Nikon Coolpix S1 - Need help.
This is a common, but unfortunately fatal problem with this model camera. Don't worry, your photos (if taken on the sd card) are all still safe and sound. Just transfer your photos to your computer.
There is nothing you can do that I know of to fix this. But there is a guy (I call him, "the cheap camera repair man"), who fixes this problem for thirty dollars. The website URL for him is:
http://www.dynamiccamera.com
I hope this helps!
Jan 04, 2008 | Nikon Coolpix S1 Digital Camera
Nikon coolpix s1 dig camera ,no picture
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Oct 13, 2007 | Nikon Coolpix S1 Digital Camera
Black Lcd and pictures.
The problem you are experiencing is due to the shutter being stuck closed. Normally the shutter is kept open while you compose the image, and then when you push the button it closes and the CCD records what it was seeing at that moment. When the shutter is stuck the image is blocked from reaching the CCD at all times so you can see nothing. Unfortunately the shutter is a tiny delicate component buried deep within the lens assembly and is not accessible without complete disassembly. I would suggest finding a repair center to ship the camera to, or replacing the camera. I would definitely not _gently_ tap the camera on a hard surface to possibly dislodge a slightly stuck shutter blade. This could easily cause further damage to the camera. However, you are not me. ;) David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix S1 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
470 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
