Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Echo 452VL chainsaw won't start
Have taken the carb off the chain saw looking for problems, but found none. Same with the fuel line. Does this model have some sort of fuel filter? I am doing this in a power mechanics high school class and am trying to troubleshoot why it won't start? Any ideas before I pull everything and can't get it back together?
  • 181 Answers
Yes it does.the filter is in the fuel tank on the end of fuel line.if it isn't the fuel line needs to be replaced and a new filter installed.there is most likely some of the fuel line in side the carb. there is a small filter inside and it usualy collects the broken fuel line there. take the carb apart oppiset of the diaphram.usualy it's the side with only one screw.carefully blow the **** from it and the saw will get fuel again and start
Posted on Feb 23, 2009
Fuel line routing
small line should be the filtered line and go to the inlet side of the carb... single screw
Nov 12, 2013 | Echo CS400 18" Chain Saw
ECHO 452VL NOT OILING CHAIN
Sounds like you have a blocked oil pump. With the flow regulator fully open and no cage filter on the end of the oil intake hose its probably pulled through dirt and blocked the pump.
Jul 27, 2013 | Echo 452vl 452 guide plates
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing2.gif while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
Sep 11, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have a Echo chainsaw model 452Vl and am not able to start it.
Hi, It does have a filter of sorts but is on the pickup inside the tank and should not need changed. Drain the fuel mixture and check all of the plastic lines and primer bulb for cracks or kinks. Put in a fresh fuel mixture that has not been sitting, (They don't run on old mix) and try starting again. The thought process is that if it starts on the starting fluid it can only be two things, old fuel or no fuel. If the fuel change doesn't work it is probably not getting fuel thru the carb, these oil mixes gum up rather quickly and if it sat for awhile with fuel in it it may need the carb cleaned. Good Luck to you, hope this Fixsya!
Feb 23, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
1,652 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
