Question about Arcsoft Print Creations - Cards & Calendars (BXPC0002)
I have downloaded and bought Simply Paisley, Signs of Zodiac,and Delicate Life calendars. In the Simply Paisley, the pictures come out fine but the calendar numbers and dates are blurry. What is going on. I really like program but can't get this to work.
  • 1 more comment
  • tiffany2004 Feb 23, 2009
    When I print it. 3 out of the 12 months came out alright, rest are blurry.
    I will try this but it prints everything else fine. Will let you know.
    Thank you
  • tiffany2004 Feb 25, 2009
    Nothing that you recommended helped. I went to the Office Max and computer guy said that the pixels had not been set to print a 8 1/2 x 11 page. I came home and tried it again on 8 1/2 x 11 and still eithre pixels or blurry. I downsized the paper to 5 x 7 and it printed just fine. BUT I had already printed the pics on 8 1/2 x 11 so wasted 30 sheets of cardstock. Please mark on the pattern how big a paper it will work on.
    Thank you
  • 4,806 Answers
Hi there.
Use the the printers software utility to clean the heads, re-align the cartridges and also manually clean the rollers on the printer and then print a test page, if all goes well try print Simply Paisley again, also check the ink levels too as i don't think its the software that's the problem but rather the printer itself.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
    Brigadier General:
  • 5,158 Answers
Blurry when you print it or on the screen ?
  • Roberta Smith
    Roberta Smith Feb 23, 2009
    it could very well be your printer that has the problem.... any issues printing anything else ?
Can't access my mail
If you are not able to access your emails on your Outlook, then you need to scan the Outlook PST file using Scanpst.exe to check for the issues and to repair the PST file but before performing any task it is recommended to backup the files. For your ease, you can also take help of PST Repair Tool that has the ability to repair corrupted, damaged, lost or even deleted and formatted emails and resolve the issues that lead to cause inaccessibility issue.
Mar 31, 2013 | Microsoft Office Professional 2007 Full...
Outlook 2007 Calendar won't open. Freezes Outlook.
Use Outlook PST Recovery software to recovers mailbox folders such as inbox, sent items, deleted items, contacts, calendars and journals from corrupt PST files and shows the recovered items in a tree structure before saving in disk
http://www.undeletepcfiles.com/outlook-email-pst-recovery.html
You just try the free trial version. to get results.
Jan 16, 2013 | Microsoft Office Professional 2007 Full...
Im wanting to remove some of my arcsoft programs that i do not use which ones can i remove without affecting the basic program?
First, make sure you have the Arcsoft disk in case you change your mind. I remember seeing the Arcsoft programs several years ago, they came with some printer I bought. If you have your Arcsoft disk, then you are free to experiment with options.
Look under Add/Remove Programs, and see how many entries you see for Arcsoft. There may just be one, I don't really know. But if there are several, then try to make intelligent choices about what you remove and what you keep. I'm not sure what you're using this for - - - anyhow, it says "Cards and Calendars", so those are the 2 main functions. Maybe if you're not using Calendars, you could remove that.
But I have a hunch it's probably just a single suite with these 2 functions built in. Let me know if this helps.
BTW, if you don't have your Arcsoft disk, I would not recommend uninstalling ANY part of the suite. For example, if it came pre-loaded on your computer, the only way to get it back may be to do a total, "factory reinstall" where you format the hard drive and put everything back the way it was when you bought it.
Thanks ~Jim :-)
Jul 22, 2011 | Arcsoft Print Creations - Cards &...
How to creat beautiful picture editing?
Photoscape try to download on the internet and you try to edit
Feb 28, 2011 | Arcsoft Print Creations - Cards &...
The answer to "Share Calendars" that comes up in
The option is usually under where you are looking at:
How to Share Calendars
Open a Shared Calendar
Share My Calendar
If the option is not there, then you can go to File>Folder>Share Calendar
Hope that helps, pls rate the solution
Nov 14, 2010 | Microsoft Office Outlook 2007: Windows
Lost all calendar data
not farmilliar with this software but it uses a database dao object file try this method open my computer go to c: drive hit the search files button or ctrl+f and type in *.ORG this is the Calendar file (Lotus Organizer)
the *.org will search for the file till it is located then it's only a matter of opening the file and making backups of your calendar information try opening the file in lotus software. usually file open or import
Aug 19, 2009 | IBM Lotus Organizer 6.1 (804526018606)
Anytime Organizer Problems
You could try using 'map network drive' to create a drive letter reference for your network file location. I don't know what operating system you're using, but you should be able to find this option in Windows Explorer.
Select a drive letter that you're not likely to use for anything else (such as X), and enter the path to the file you're trying to use.
( //<your server>/.../ ).
Once this is done you can refer to the file as X:/<your file name> instead of //<your server>/../<your file name>
I hope this helps, let me know if you need any more detail on this!
Mar 13, 2009 | Individual AnyTime Organizer Deluxe 9.0...
Microsoft Office/Outlook 2007 calendar crashing
Perhaps this problem has many different ways of resolving. For example I've known some interesting tools for working out like issues, one of the most effective is the next - outlook pst repair.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
Outlook 2007
Most reported problems of this type have involved the Calendar, and allowing the display of tasks. If your calendar is activated, and tasks permitted to display simultaneously (default operation), this is often the cause.
If this does not apply to your situation, we can investigate further, if you could tell me a little more about your OS and hardware. Thanks for rating FixYa!
Apr 29, 2008 | Microsoft Office Professional 2007 Full...
Stacked Bar/Column chart with Negative Values
use a line chart instead with up/down bars
Nov 01, 2006 | Harvard ChartXL 3.0 (163103)
Arcsoft Print Creations - Cards & Calendars (BXPC0002) Logo
29 people viewed this question
Top Arcsoft Computers & Internet Experts
Clive Gray
venugopal durairajan
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
